Empty directory copying error
mapiet
Using WinSCP 5.1.8 (build 3799) with “Commander” interface on Windows 2000 SP4.
The situation looks that:
I have one directory on the local machine and the one directory in the remote destination (this same name of directory). Both directories are empty. If I try copy empty directory from local machine to remote destination (override), an error message appears: "Copying files to remote side failed. Error creating folder 'folder name with path'. folder name: File exists". I am using the Default transfer settings.
Re: Empty directory copying error
The error message is actually misleading.
The actual problem is here:
> 2013-12-07 09:14:18.551 MLST /m.ptr/Program SN/tmp_tmp/tmp_dir
< 2013-12-07 09:14:18.551 501 Invalid number of arguments
Your server fails MLST command for some reason. Possibly it gets confused with the space in the path.
mapiet
That's true. I checked it a moment ago. This problem is bound with spaces in path. What is guilty: the FTP server or WinSCP application?
mapiet
I have to add: The other FTP client (Total Commander) work fine in this same situation, even if in the path are some spaces.
TC possibly does not use MLST command. Your server does not seem to have problems with other commands.
mapiet
Will you do something with this problem in future (in WinSCP application)? Whether the problem there is only in my computer or in remote computer (i.e. in the FTP server) and it must be resolved by me?
I do not think that WinSCP is doing anything wrong. So, no, I do not plan to change anything. Please contact your FTP server software vendor.
mapiet
Maybe WinSCP should use quotes around pathname strings? Probably then would be no problems with spaces in path, in any operating systems.
There's nothing about quotes in the FTP specification. So such a change will likely break more than it would fix.
