Monospace font for 'server prompt' window?
Some server I want to connect to use a ASCII-based CAPTCHA https://github.com/jordansissel/pam_captcha. This works fine with tools like ssh and PuTTY. However WinSCP uses a non-monospace font which screws up the CAPTHA. Is it possible to use a monospace font in the 'server prompt' window to fix this? Thanks in advance!
Cheers,
Jeroen
Description: putty versus winscp
Re: Monospace font for 'server prompt' window?
I would not like to make monospace font default. But it can be optional. Or WinSCP can try to autodetect need to use monospace font somehow.
Any chance of getting a test account on your server?
All sound good to me...
Unfortunately access to a production server is not possible. Setup on Ubuntu, on a root prompt:
wget <invalid hyperlink removed by admin>
cd /opt
tar xfz /tmp/pam_captcha-1.5.tar.gz
apt-get install libpam0g-dev
apt-get install figlet
make
cp  pam_captcha.so /lib/security/.
vim /etc/pam.d/sshd
--> add first line
auth       requisite     pam_captcha.so    math dda randomstring
vim /etc/ssh/sshd_config
--> add / unremark
PasswordAuthentication no
ChallengeResponseAuthentication yes
If this is not working for you, please let me know and I'll setup a test VM.
Cheers,
Jeroen
That would be great!
Inuya5ha
Argentina
Now that we are on the fonts topic, the Enter Command text box from the Console window should use a monospace font as well, just like the log window which is now using Lucida Console.
ADTC
Workaround
Until this feature is added, a simple workaround would be to copy the text to Notepad or something monospaced :) Assuming that you can actually copy it from the WinSCP window, of course.
g.synedra
I second that monospaced font should be used in the server prompt.
We use figlet inside our banners and those get mixed up as well.
omg... Many apologies! I don't understand how I misread this and misunderstood prompt for banner. Must have been tunnel vision as I was missing a monospaced font for the banner and I only saw what I wanted to see.
