Compatibility with SecureFTP server
Re: Compatibility with SecureFTP server
AFAIK SecureFTP server is not SFTP server, so you cannot connect to it with WinSCP.
SecureFTP supports FTP protocol over SSL channel, which is completely different protocol to SFTP.
setver
New Jersey, USA
Tom Osborne wrote:
How does this product connect with SecureFTP?
Are you talking about Globalscape Secure FTP server 2.0? I'm using WinSCP for SFTP transfers with that server. The only problem is that the timestamps displayed in WinSCP for the files and directories on the remote side are way off.
