Problem with winscp in two versions
Mahdi Bashiri
Hi
i have connect to remote ftp server to sync. many files as daily job.
the remote ftp server company send me winscp 4.1.2 and it work without any problem, but when i have updated to new version ( 5.1.7 or 5.2.7RC) the connection process ask me to re enter password and does not login as you in attached image.
Regards,
Mahdi
Re: Problem with winscp in two versions
Please attach a full log file showing the problem (using both 4.1.2 and the latest version of WinSCP).
Mahdi Bashiri
i don,t know how can i enable logging in winscp 4.3.2( excusme the old version was 4.3.2 not 4.1.2)
also i send you the log file for winscp 5.1.7
Ok, but I need also log from the version that works (4.1.2). See above.
