Synchronization upload/download icon colors are confusing
Ciantic
Finland
I use the synchronization as well as auto-remote synchronization a lot.
I don't know if the icons in synchronization dialog changed, but I think in past the upload arrow was in single color and download was in another color. This is not the case at the moment, some binary files make the things a bit harder as you may have green arrows meaninig upload and red arrows meaning upload.
It was easy to glance that all is only uploading, or downloading, now I need to look each differing color of arrow independently this makes things a somewhat slow.
Can I change the icon theme? I like the new icons, just that upload arrow needs to be in single color and download in single color.
Thanks.
P.S. Problems started to appear as I upgraded to WinSCP 5.2.7 RC, from 5.1.x
Re: Synchronization upload/download icon colors are confusing
The only relevant change in 5.2.x was that update color is now red, rather than blue. There was no single color for upload and download ever. Anyway, we will consider observation.
