connect via http proxy
Falcong
Hi ,
how is difference bettwen connectig with total commander and winscp ? If I try connect to ftp over winscp the winscp return error
Error retrieving server address, cannot test if address is routable
Proxy request failed, can't connect through proxy server
Transfer channel can't be opened. Reason: An established connection was aborted by the software in your host machine.
if i try from total commander or altap , that is ok :(
thanx
Re: connect via http proxy
Please attach a full log file showing the problem using both the latest (beta/RC) version of WinSCP and Total Commander and/or Altap Salamander.
