Getting router to talk to FTP
guest
Hi – I am sorry but I am a rookie at this and can't figure out how to even access the 'Logging' tab. Recently my internet died and I had to replace the modem (which is connected to a router) and reinstall the ethernet card – since then I have not been able to use WinSCP – SCP is the transfer protocol I use, it's connecting through Port 22. It will let me download stuff from my remote site, but not upload from my local to the remote – it says 'host not answering after 15 seconds' and aborts. Do you know what to do about this?
Re: getting router to talk to FTP
Logging tab reveals if you check "Advanced options" below navigation bar of Login dialog.
You may also try SFTP protocol instead of SCP.
Re: Sftp not login in TP LINK WIFI Router ? how to setup
@nil: Do you mean that the SFTP on your router does not work with WinSCP? Then please post WinSCP session log file and a log file of any other SFTP client that works. Or do you mean that the SFTP does not work at all on your router? Then it is not WinSCP question.
