session->Dispose and odd server behavior
lmattera
Setup:
Windows 2008 (32 Bit)
WinSCP 5.1.7 & COM library
Using Active Perl and Win32::OLE to access library.
I've got an oddball SFTP server that only updates contents on acknowledgement of a QUIT command.
For some reason $session->Dispose () is not sending this so every time I log in it retrieves the same files.
If I log in through WinSCP itself and then disconnect the server updates properly.
I tried using $session->ExecuteCommand ( 'quit' ) but I don't have authorization rights to run it.
Is there any way I can force this?
Re: session->Dispose and odd server behavior
There's no quit command or anything similar in SFTP.
Anyway, please attach a session log file both from .NET assembly (set Session.SessionLogPath) and GUI.
