COM library putFiles giving error on VBA
PeBoe
Hi
I'm trying to use the COM object in VBA; after successful creation and initialization of a session object which I call m_session I try:
Dim transferResult As TransferOperationResult
transferResult = m_session.putFiles(localPath, remotePath)
also tried:
set transferResult = m_session.putFiles(localPath, remotePath)
But I always get an Error: "object reference not set to an instance of an object"
NOTE: I know m_session is OK, because when using it with m_session.ExecuteCommand('any UNIX cmd') it works fine
Working with:
Microsoft Windows XP Professional; Version 5.1.2600 Service Pack 3 Build 2600
Microsoft Visual Basic 6.5
WinSCP 5.1.7
WinSCP COM Assemmbly 5.1.7
Thanks for your help
PeBoe
PeBoe wrote:
I'm working with Excel 2003 SP3
I would not expect this to differ between 2003 and 2010.
Anyway, can you post your complete code?
PeBoe
Sorry Martin
after further playing around with my example code I discovered my error (an uninitialized variable within my method); as often, just a copy/paste error :evil:
After the small correction, the code runs perfectly !
Thanks a lot for your efficient support :D
Friendly regards
P.Boehm
