Use WinSCP with agent forwarding, but without pageant
ManuelK
I have a fairly strange question.
I am in an environment where they use a certificate for authentication, and they required agent forwarding.
If i register the certificate in pageant, an set the config value "Attempt authentication using pageant" and "Allow agent forwarding" to true i can connect and everything works.
For some reason, i cannot use pageant. I want to set just the key and to authenticate via the certificate, but i still have to allow the agent forwarding.
But in this scenario, the server will return "Missing authentication agent request".
Question:
Is it possible to use agent forwarding without using pageant? If yes, how?
Thanks in advance.
Re: Use WinSCP with agent forwarding, but without pageant
Agent forwarding without the agent? That does not make any sense. What do you want to do actually?
I need to run this as windows service, and there seems to be no way to access pageant via windows service.
manuelk
I want to call a sftp server via winscp from a windows service process.
Between me and the sftp server, there is a ssh proxy.
I have to use agent forwarding in order to authenticate.
I can enable agent forwarding in winscp, but it seems it requires pageant.
I cannot use pageant from a windows service(It's just not possible because of security reasons).
Question:
Is it possible to use winscp with agent forwarding and without pageant?
No you cannot use agent forwarding without the agent.
What happens if you specify the key both for tunnel/proxy authentication and the actual session? Can you post a log file?
