5.1.7 Scripting pushes files every time ran; likely DST iss
Hutch8729
Hey guys. Every time I run my script today its sending every file out to my remote computers. Was not happening yesterday. With DST being last night it makes me believe this is the culprit. All remote computers are win7 with filezilla ftp server and the source computer is win7 with winscp 5.1.7 using batch file
"<pathtowinscp>" /console /script=<path>
and script
option batch on
option transfer binary
open ftp://<user>:<pass>@<site>:21 -passive
synchronize remote <localpath> <remotepath>
close
I have tried adding the -rawsettings ConsiderDST=0 switch to the open command with seemingly nothing changing. Any help or suggestions would be greatly appreciated. Thanks!
Please attach a full log file showing the problem (using the latest version of WinSCP). Ideally on a small subset of the files (even one).
Re: Log
Thanks for the log.
