Wildcards are not working with Get
DwoodardKS
I am using a wildcard with my get and it is still downloading all of the files in the directory. Has anyone else had this problem?
Re: Wildcards are not working with Get
Ok, I suppose that you want to do: get remits/P8*.rmt \\Dadkins_pds\d$\TTG\Train\Remits.
What you are doing atm (get P8*.rmt remits ...) means, download all P8*.rmt files from current directory (there are none) and whole remits subdirectory.
