Directory contents are empty
cny
I'm using the standalone WinSCP with the .NET/Powershell extension in a powershell script. It works reasonably well, but there is sometimes a directory that WinSCP report as being empty (only consisting of ".."), when it is not.
Here is the example code I use:
. .\common.ps1
try
   Add-Type -Path "..\WinSCPnet.dll"
    # Setup session options
    $sessionOptions.HostName = "ftp.domain.com"
    $sessionOptions.UserName = "UserName"
    $sessionOptions.Password = "Password"
    $sessionOptions.SshHostKeyFingerprint = "ssh-dss 1024 asdfasdfasdfasdfasd random asdfasdfasdf"
   try
      # Connect
      $directoryInfo = $session.ListDirectory("/remote/directory/path")
      $dirFiles = $directoryInfo.Files
      #$dirFiles would only contain ".." if I iterated over it
   finally
      # Disconnect, clean up
      $session.Dispose()
    exit 0
catch [Exception]
    $_.Exception.Message | out-file $outputFp -encoding ascii -append
    exit 1
Curiously enough, when I ran most of this script by typing out lines (instead of running the script containing them), I think that directory's contents were shown to be correct. So I'm a little confused. Does anyone see any problem with the above code?
Re: Directory contents are empty
To generate log file, set Session.SessionLogPath. Submit the log with your post as an attachment. Note that passwords and passphrases not stored in the log. You may want to remove other data you consider sensitive though, such as host names, IP addresses, account names or file names (unless they are relevant to the problem). If you do not want to post the log publicly, you may email it to me. You will find my address (if you log in) in my forum profile. Please include link back to this topic in your email. Also note in this topic that you have emailed the log.
