how to use a stored session with powershell
wleddy
Is there a way to reference a stored session when using powershell?
requires having the plain text password to use when building $sessionOptions, something I saved as a stored session so I wouldn't need it.
Is there a form something like
$session.OpenSession($sessionName)
to use all the settings available for the GUI session?
Or a callable method that will return the decrypted password given a session name, which could be used in building $sessionOptions?
Thanx,
Bill
Re: how to use a stored session with powershell
WinSCP .NET assembly is deliberately isolated from WinSCP configuration by default. While you can hack it to use the stored session/site, I would not recommend it.
That's not a good argument. Note that the password stored in the stored session/site can be easily recovered too. You need to ensure safety of your machine to protect the password.
See https://winscp.net/eng/docs/security_credentials
wleddy
Thanx for the reply. I have a work around saving (get-credential).password as a secure string file and then converting *that* to text. I was hoping for something less cumbersome (among other things, this requires the service account that is running the scheduled tasks of interacting with a remote SFTP server to have local log-on privs in order to save the secure string, something which has its own security risks) but I can appreciate the need for password security.
Running this under special account to protect the credentials is IMHO the only correct way.
