Unable to launch WinSCP: "Master password handler not set"
Y-Phil
Hi
I was using the V5.24 on a Win7/64b plateform. It works well. So does the V5.25, with one disturbing exception.
If I make an empty winscp.ini file with V5.24, with one sftp entry, and protect it with a password, the V5.25 will use it without problems.
But with my current INI file, which has 40-50 entries and folders:
- no password: no protection, but no problems: the V5.25 loads it correctly
- with a master password, whichever it is: the V5.25 fails with the message: "Master password handler not set"
How can I help you without giving my INI file?
Thanks in advance.
Kind regards.
Y-Phil
Re: Unable to launch WinSCP: "Master password handler not set"
-bob
I am also seeing this after upgrading. Possible related items -
1) I downloaded and started the upgrade while WinSCP was running and received the "close WinSCP and continue" message (which I did).
2) I do not think that the master password was typically requested on startup of WinSCP (rather not until I tried connecting to something that required it).
3) Now, I simply cannot start WinSCP - I just get the message and it exits after clicking OK.
Let me know if there is a work-around or fix.
Thanks,
-bob
Can you send me an email, so I can send you back a development version of WinSCP for testing? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
