lag on folder changing
kino
First - this is a great looking program, I am very impressed by the layout and functionality. I just have one problem which is stopping me using it full time, the lag when opening folders. I don't seem to get this effect on ftpvoyager. Is there something I can do to speed this up either on the server or locally on the software/my pc. The delay is small, only 2-3 seconds but annoying.
TIA
Kino
kino
Hi prikryl,
Thanks again for the program and the reply.
It's on the remote folders, local ones are fine. I'm using XP Pro here connecting to a RHE 3 server running OpenSSH 3.6.1p2-19 and ProFTPd 1.2.9. Could this likely be something addressed by updating the server versions of these programs?
Best regards,
Kino
Re: lag on folder changing
I do not know. The reason may be that your other client has caching on, while you have turned it off in WinSCP. Also note that WinSCP does not have persistent cache, while the other client may have it.
