5.2.5 Beta .Net assembly not presenting password
SteveFCT
I am automating ftp transfers using PowerShell and the .Net assembly. It has been working using 5.1.7. I wanted to use the ResumeSupport so installed the 5.2.5 beta. The script now fails, and by using WireShark I can see that the Password is not being presented. Only the FTP command PASS, followed by 0D0A (crlf) is sent to the server.
If I revert to the 5.1.7 assembly it works again, and I can see the password being presented correctly.
Re: 5.2.5 Beta .Net assembly not presenting password
To generate log file, set Session.SessionLogPath. Submit the log with your post as an attachment. Note that passwords and passphrases not stored in the log. You may want to remove other data you consider sensitive though, such as host names, IP addresses, account names or file names (unless they are relevant to the problem). If you do not want to post the log publicly, you may email it to me. You will find my address (if you log in) in my forum profile. Please include link back to this topic in your email. Also note in this topic that you have emailed the log.
SteveFCT
[/size]
I have generated the logs from both 5.1.7 and 5.2.5 and emailed them in a zip file.
Steve
