Error opening session throug tunnel
underdpt
I've a connection through a tunnel, that was working with previous release. After upgrading, If I try to use that connection it gives an error (details follow). Opening a session on the first server (the one that has to open the tunnel to the second one) works correctly.
Ask me if you need more info.
WinSCP 5.2.5
Using username "root".
Access denied.
Authentication failed.
Re: Error opening session throug tunnel
