WinSCP client all time stamps that we FTP'd show -7 hours
kenp11
United States
When we login with WinSCP client all time stamps that we FTP'd show -7 hours behind PST. GMT is 7 hours ahead.
PST time 2:22PM time of file on PC & Windows server
Winscp 7:22AM
GMT is 9:22PM
How do we fix this so time stamps match local PST?
Re: WinScp client all time stamps that we FTP'd show -7 hours
What version of WinSCP are you using? Do you use FTP or SFTP?
kenp11
United States
Currently on version 5.1.7 Build 3446. FTP port 21 Attached log
FTP zip file at 9:30 but time of the file on server is different. Changed time is 2:30am on WinSCP folder remote.
Description: FTP zip file at 9:30 but time of the file on server is different. Changed time is 2:30am on WINSCP folder remote
Re: Logs
Thanks. What particular file should I look at? What time do you expect WinSCP to show?
In the log, I can see you were uploading file ReleaseBulletinCPBA1.0.3.3_20131022.pdf. But it seems that the server did not accept a timestamp at all. It not just a timezone difference. The source local file is dated 2013-10-23, while after upload the destination remote file has date 2013-11-07 (i.e. today as the time of transfer).
Re: Logs
Yes. The file Release Bulletin. On the GUI of Winscp it shows 2013-11-07 and 7:29 am and the time stamp of PST -7 hours when it is 14:29
Re: Logs
On a local panel before upload or a remote panel after upload?
