No reconnect when connection is dropped - Batch
SanchesMatheus
Dears,
I created a script file and I need if he lose connection abort the transfer.
My script:
winscp /command "option confirm off" "open sftp://User:Pasword@SFPTServer" "cd dir" "put file" exit /log=File.log
Matheus Sanches
Re: Abort trying to connect
rmtarget wrote:
option batch abort does not work for me (in my script)!!
