Display files with cyrillic/russian file names?
pstein
I logged in into a remote server and navigated to a certain directory.
Much to my surprise a couple (all) files with cyrillic/russian file names are NOT displayed correctly.
Instead some special char mess is displayed.
The file names themselves are correct. I could read them through other clients
FileZilla.
How can I read the correclty as well in WinSCP? Is there an option?
Peter
Re: Display files with cyrillic/russian file names?
That screenshot is for Login dialog, not for Preferences dialog. In the latest beta the option is available in Advanced session setting dialog.
pstein
Ok, thank you. I am used to call WinSCP immediately by a shortcut with a predefined session name as parameter. So I hardly ever stopped at the login page.
However I had difficulties to change the UFT option for such an already existing session.
After I manually (!) added the line
Uft=1
in winscp.ini section for this session everything worked fine. This is somehow unhandy.
Could you move this option into a session option set (rather than login option set)?
Thank you
What kind of difficulties?
What do you mean by "session option set" (as opposite to "login option set")?
