VB.NET: "The file exists." error while opening Session
Suresh
Malaysia
I developed an VB.NET application to monitor the files in SFTP folder periodically. The application uses Winscp.dll. I am using Windows Task scheduler and called the application.
I am getting following error while connecting WinScp using Session.Open method.
Code Snippet
Imports WinSCP
Try
   WriteInLogFile("Process Starts...")
   Dim sessionOptions As New SessionOptions
   With sessionOptions
        .Protocol = Protocol.Sftp
        .HostName = HostName
        .PortNumber = PortNumber
        .UserName = UserName
        .Password = Password
        .SshHostKey = SSHHostKey
    End With
   Using session As Session = New Session
      session.Open(sessionOptions)
      WriteInLogFile("Session starts...")
      Dim directory As RemoteDirectoryInfo = session.ListDirectory(SourcePath & FileType)
      WriteInLogFile("Process Ends...")
   End Using
Catch e As Exception
     WriteInLogFile("Error : " & e.Message.ToString)
End Try
Error
Error : The file exists.
The scheduler is running in local Adminstrator account.
Windows Server Details
Windows Server 2008 R2 Enterprise- 64 bit OS
WinSCP
WinSCP 5.0.6 (Build 2074)
Kindly note that the Session opened properly when the same application executed manually by double clicking the exe.
Since the application is working fine when we execute manually and also the error message is not proper, we are unable to proceed our analysis.
Kindly suggest possible causes for this scenario and provide me a solution.
Suresh
Reply with quote E-mail
Suresh
Malaysia
After I clear the temp folder, the scheduler is working fine.
Ref: https://winscp.net/forum/viewtopic.php?t=11184
But I wonder, why Winscp creates temp files in temp folder and why this problem is not occurred while executing the application manually.
Kindly let me know if anyone has information regarding this.
Thanks & Regards
Suresh
Re: VB.NET: "The file exists." error while opening Session
This was know bug:
https://winscp.net/tracker/849
You need to upgrade.
This is how it communicates with winscp.exe
Possibly your interactive session uses a different temp folder than your schedulers session.
