WinSCP vbscript needing to set proxy credentials
barnettj68
Our company acquired another and I've inherited an existing WinSCP VBScript. The server the script was running on didn't require proxy authentication. We're moving it to our network and it will require authentication. When I use the GUI and setup the session to use my proxy credentials I have no problem. I'd like to use WinSCP and the existing script. Is it possible go through a proxy via script using WinSCP .NET assembly/COM object like you can do with the GUI?
