Update script file for changing file name
Our vendor made a change and now we have to modify a script that we have been using for quite some time. Not really sure how to modify it.
What it currently looks like:
What we have to do now is change the filename to FileMMDDYYYY.txt using the current days values. Is there an easy way to do this?
# Automatically answer all prompts negatively not to stall # the script on errors option batch on # Disable overwrite confirmations that conflict with the previous option confirm off # Connect using a password # Connect open sftp://xxxxxxxxxxxxxxx -hostkey="xxxxxxxxxxxxxxxxxxx" # Upload the file to current working directory option transfer ASCII put "\\myfilepath\File.txt" -nopermissions -nopreservetime # Disconnect close # Exit WinSCP exit
