Need help with D/L speeds over SFTP
nzdreamer55
Hello everyone,
I want to start using WinSCP for moving files from my server to my home computer, however when I do I have very slow D/L speeds like < 1 Mb/s (single file transfer). When I use CuteFTP I get 25-30 Mb/s (again single file transfer not split into parts).
Can someone help me start to trouble shoot why I get slow speeds with WinSCP?
-N
Re: Need help with D/L speeds over SFTP
nzdreamer55
Thanks for the help. I choose normal mode and when I chose debug 1 or 2 things really slowed down and I didn't get a normal log file. I tried to remove any information that I thought would be bad to post openly (passwords, usernames, etc.) I noticed that I am using compression when transferring the files and maybe that isn't needed if the files are encrypted? Maybe that is a lot of work for the server or my computer?
-N
Thanks for your report. Can you email me a Debug 1 log file anyway? Ideally for a single file mid-sized file only. Turn off compressions to rule it out.
kepposeppo
Hi
I have same problem and it is same with older, default and newest version. I also get decent speeds using other SFTP programs but with WinSCP download speed is one tenth of the upload speed from/to my SFTP server...
