[Request] Adequate behavior when pasword change is required
braykov
There are servers that are setup to expire user passwords on a set interval.
In this case, WinSCP just doesn't do anything upon login attempt.
I try to login, the login window closes and nothing hapens.
Please, add to WinSCP that it detects such cases and shows up a window with a warning and request for the new password. (It MUST not allow for reconnect.)
Then it should try to change the password and also remember the new password for this connection.
This is extremely important to us. As now current behavior causes our accounts to get locked. :cry:
billy2393
HK
Re: [Request] Adequate behavior when pasword change is required
My version (5.1.3) does not have this issue. It will display password box if stored password is incorrect.
braykov
This request is not about prompting when the password is wrong.
The password is correct, but the server won't log you because it requests a password change.
WinSCP cannot do more than what it already does:
https://winscp.net/eng/docs/task_change_password
