COM methods not visible [solved]
piedmont
UK
Hi Martin,
I'm trying to use the COM version of the .NET wrapper. The dev environment is Microsoft Dynamics NAV (a version which supports only COM DLLs)
I've followed the installation instructions in https://winscp.net/eng/docs/library_install
I'm now able to see the DLL as an available variable type. However when i create variables of type 'WinSCP console interface .NET wrapper'.Session or SessionOptions, no methods or properties are visible/available. (The only type which has visible methods is ISessionEvents)
When we develop custom DLLs for Dynamics NAV (in Vis Studio), we have to specify both the DLL and methods to be COM visible - otherwise we get similar behaviour to the above.
Is there anything we can try to resolve this?
Many thanks in advance,
Piedmont
OS: Windows 2003
WinSCP version: 5.1.7.3446
Re: COM methods not visible
WinSCP .NET assembly has late binding interface, if that's what you ask about. If you need early binding interface, you can download the assembly source code and change WinSCP.Constants.ClassInterface to ClassInterfaceType.AutoDual.
nikonjoh
Same Issue, while I can see the DLL functions, I cannot see thier methods
It looks like piedmont was able to change the source and compile and get the .Net Com to work in Dynamics NAV. I am not so talented in the build/compile department.
Is this the current mod needed to resolve this issue?
Thanks,
nikonjoh
Re: Same Issue, while I can see the DLL functions, I cannot see thier methods
Not sure I understand your question. But there was no change in this respect, if that's what you ask.
TNDinh
Share DLL of WinSCP to developing in NAV 5.0
Dear Piedmont,
Could you please share me object that you have changed for developing in Nav 5.0?
TNDinh.
