Trouble with special character in password
k3flo
Deutschland
i'm trying to connect to an SFTP Server using the latest beta release (5.2.4 beta).
Connecting via WinSCP.exe works fine.
Connecting via .NET (4.0) assembly fails on password authentication.
I reflected the WindSCPnet.dll and found the issue. The SessionOptionsToOpenArguments()-method in Session.cs Uri-escapes the Password using Uri.EscapeDataString(). The problem is that the Uri.EscapeDataString()-method returns %C2%A7 for the character § instead of %A7 which is expected.
Any ideas to force the Uri.EscapeDataString()-method to return %A7 instead of %C2%A7?
Any other ideas?
Thank you.
