Scheduled task to upload files for only current day?
comfortablynumb
I need to create a scheduled task that will upload files only for the current day. I looked at the synchronize option but that won't work as I don't control the destination directory.
I could use synchronize if there was a way to have WinSCP only look at files created or modified on the day the task runs, and I have to schedule this task to run multiple times per day, then email the results.
Can anyone help?
Thank you!
Re: Scheduled task to upload files for only current day?
Why that means you cannot use synchronize?
If you want to upload files with modification date in a certain day, you need to generate the script on the fly with the certain date.
There are many examples on how to generate timestamp into script, e.g. here:
Downloading file to timestamped-filename
