Installation error
CoachKA
Installation error
I am trying to install WinSCP version 5.1.7 on a Windows 7 Enterprise HP laptop. I have selected the default installation settings and receive the following error: Internal error: Failed to expand shell folder constant "userdesktop". My Desktop, Favorites and Personal/Documents directories are on a network drive. I have updated the registry entries, but I still receive the error.
Here is the log file from my last install attempt:
2013-09-16 11:11:18.846 Log opened. (Time zone: UTC-07:00)
2013-09-16 11:11:18.846 Setup version: Inno Setup version 5.4.3 (u)
2013-09-16 11:11:18.846 Original Setup EXE: C:\Users\xxxxx\Downloads\winscp517setup.exe
2013-09-16 11:11:18.846 Setup command line: /SL5="$C093E,4520388,140800,C:\Users\xxxxx\Downloads\winscp517setup.exe" /SPAWNWND=$A06B2 /NOTIFYWND=$1405BA /log="winscpinst.log" /saveinf="instsave.txt"
2013-09-16 11:11:18.846 Windows version: 6.1.7601 SP1 (NT platform: Yes)
2013-09-16 11:11:18.846 64-bit Windows: Yes
2013-09-16 11:11:18.846 Processor architecture: x64
2013-09-16 11:11:18.846 User privileges: Administrative
2013-09-16 11:11:20.221 64-bit install mode: No
2013-09-16 11:11:20.221 Created temporary directory: C:\Users\xxxxx\AppData\Local\Temp\is-GS4TG.tmp
2013-09-16 11:11:28.771 License accepted
2013-09-16 11:11:35.992 Starting the installation process.
2013-09-16 11:11:35.992 Warning: SHGetFolderPath failed with code 0x80070003 on folder 0x8010
2013-09-16 11:11:35.992 Fatal exception during installation process (Exception):
2013-09-16 11:11:35.992 Exception message:
2013-09-16 11:11:35.992 Message box (OK):
2013-09-16 11:11:38.835 User chose OK.
2013-09-16 11:11:38.835 Message box (OK):
Setup was not completed.
Please correct the problem and run Setup again.
2013-09-16 11:11:40.641 User chose OK.
2013-09-16 11:11:40.641 Rolling back changes.
2013-09-16 11:11:40.641 Starting the uninstallation process.
2013-09-16 11:11:40.641 Uninstallation process succeeded.
2013-09-16 11:11:42.149 Deinitializing Setup.
2013-09-16 11:11:42.149 Preparing intallation report
2013-09-16 11:11:42.149 Sending installation report: <invalid hyperlink removed by admin>
2013-09-16 11:11:42.492 Installation report send result: 200 OK
2013-09-16 11:11:42.507 Log closed.
Re: Installation error
Thank you for the suggestion. I saw this post, but Windows 7 doesn't have the same issues as Windows XP.
I actually solved the issues late yesterday. The shell folder for my desktop was updated with a mapped drive reference. I had to update the reference to a fully qualified/UNC reference. I was able to install the WinSCP client.
nick0208
Failed to expand shell folder constant “userprograms” - “SHGetFolderPath failed with code 0x80070002
I get the following error on Windows 10 when installing via the system account or SCCM "Failed to expand shell folder constant “userprograms” - “SHGetFolderPath failed with code 0x80070002"
This error only happens when installing with the System account or SCCM the first 2 times on Windows 10. If install with just the administrators account it doesn’t happen at all. In addition,
SHGetFolderPath has been a deprecated function since Windows Vista.
2016-02-03 15:05:14.549 Log opened. (Time zone: UTC-05:00)
2016-02-03 15:05:14.549 Setup version: Inno Setup version 5.5.5 (u)
2016-02-03 15:05:14.549 Original Setup EXE: C:\Windows\Temp\WinSCP\WINSCP~1.EXE
2016-02-03 15:05:14.549 Setup command line: /SL5="$1001BE,5331554,166912,C:\Windows\Temp\WINSCP~1.EXE" /VERYSILENT /LOADINF=64bit.inf /NORESTART /NOCANDY /LOADINF=64bit.inf /LOG=C:\PROGRA~2\Pkglogs\WinSCP\WINSCP~1.6\Vendor_INST.LOG
2016-02-03 15:05:14.549 Windows version: 6.3.9600 (NT platform: Yes)
2016-02-03 15:05:14.549 64-bit Windows: Yes
2016-02-03 15:05:14.549 Processor architecture: x64
2016-02-03 15:05:14.549 User privileges: Administrative
2016-02-03 15:05:14.549 64-bit install mode: No
2016-02-03 15:05:14.549 Created temporary directory: C:\WINDOWS\TEMP\is-VJQCH.tmp
2016-02-03 15:05:17.221 Extracting temporary file: C:\WINDOWS\TEMP\is-VJQCH.tmp\commander.bmp
2016-02-03 15:05:17.550 Extracting temporary file: C:\WINDOWS\TEMP\is-VJQCH.tmp\explorer.bmp
2016-02-03 15:05:17.878 Extracting temporary file: C:\WINDOWS\TEMP\is-VJQCH.tmp\paypalcard.bmp
2016-02-03 15:05:17.878 License accepted
2016-02-03 15:05:17.878 Warning: SHGetFolderPath failed with code 0x80070002 on folder 0x8002
2016-02-03 15:05:17.878 Exception message:
2016-02-03 15:05:17.878 Message box (OK):
Internal error: Failed to expand shell folder constant "userprograms"
2016-02-03 15:05:51.993 User chose OK.
2016-02-03 15:05:51.993 Deinitializing Setup.
2016-02-03 15:05:51.993 Preparing intallation report
2016-02-03 15:05:51.993 Sending installation report: <link removed by admin>
2016-02-03 15:05:52.008 Error sending installation report: WinHttp.WinHttpRequest: The server name or address could not be resolved
2016-02-03 15:05:52.805 Log closed.
Re: Failed to expand shell folder constant “userprograms” - “SHGetFolderPath failed with code 0x80070002
Can you send me an email, so I can send you back a development version of WinSCP for testing? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
