how can I make sure whether the directory is exit or not
xxkwanglei
zhejiang.china
in .NET C#
before using seesion.CreatDirectory("PATH") to create directory,I want to make sure whether the directory is exit or not?
how can I do?
xxkwanglei
Re: how can I make sure whether the directory is exit or not
thanks
the example shows whether a file in the directory or not, my question is how can I make sure whether the directory is exit or not,if the directory is not exit ,I have to create it before put files in the directory.
xxkwanglei wrote:
thanks
I'm not sure if understand your problem. Anyway, note the the method works for directories too.
