3000 and more files to download in one execute process
kumar1pr@...
Hi guys!
I have situation in which I have more than 3000 files of small size to download. Currently my time out time is around 1 hour. When I am connected to my remote ftp server, I can download all the files using GUI. But when I am using script task inside SSIS package, I am able to download say 700 files and then my package would be fail.
Error Message: The process exit code was "1" while the expected was "0".
Any help would be appreciated!!!
Re: 3000 and more files to download in one execute process
