Help: Can't get Environment/Directories to "stick"
jeremym
Wilmington, DE
Hi.. I've used WinSCP a lot, but decided
to get serious with it recently.
My problem is this:
If I enter in directories in the REMOTE and LOCAL directory dialog boxes, and click SAVE, things are great for THIS SESSION ONLY.
If I exit WinSCP and come back in, the fields are blank and I have to repopulate them with the REMOTE and LOCAL directories again (very frustrating.)
Can someone help me troubleshoot this?
Thanks!
Re: Help: Can't get Environment/Directories to "stick"
All options (except for logging options) of login dialog can be saved to "stored session" on "stored sessions" tab.
jeremym
Wilmington, DE
Except that it isn't saving. :?:
Even though I click SAVE,
as soon as I close that session,
and come back in... They are gone.
Can I verify somewhere that the
directories are actually being
written to a storage location?
ie: Registry? File?
Thanks in advnce.
ie: Registry? File?
[HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Sessions]
