Script: Copying files to remote side failed Can't open data
EnT
I am running this command:
WinSCP.com /script=Cor.txt
which runs this script:
open xxx.xxx.net -passive=on
option transfer binary
lcd "t:\\Client reporting\Equi FTP HotFolder"
cd /
cd "Development/In/Client Reporting/Hot Folder"
put -delete *.*
But it always fails (at different point/files) mid way through coping the files with this error:
futnfwds.pdf | 4144 KiB | 4099.4 KiB/s | binary | 100%
fx.pdf | 0 KiB | 1502.5 KiB/s | binary | 0%
Error transferring file 'fx.pdf'.
Can't open data connection.
Can you advise what the problem may be? Here is the log:
(I have changed some of the more company specific information)
. 2013-09-06 14:32:29.440 --------------------------------------------------------------------------
. 2013-09-06 14:32:29.440 WinSCP Version 5.1.7 (Build 3446) (OS 6.1.7601 Service Pack 1)
. 2013-09-06 14:32:29.440 Configuration: D:\Apps\Batch\Prod\Scheduled_Tasks\Miscellaneous\Cor\winscp517\WinSCP.ini
. 2013-09-06 14:32:29.471 Local account: AMI-LONDON\svr_dimenbatchprod
. 2013-09-06 14:32:29.471 Working directory: D:\Apps\Batch\Prod\Scheduled_Tasks\Miscellaneous\Cor\winscp517
. 2013-09-06 14:32:29.471 Process ID: 55416
. 2013-09-06 14:32:29.471 Command-line: "D:\Apps\Batch\Prod\Scheduled_Tasks\Miscellaneous\Cor\winscp517\WinSCP.exe" /console=517 /consoleinstance=_60972_403 "/script=Cor.txt" "/timeout=60"
. 2013-09-06 14:32:29.471 Time zone: Current: GMT+1, Standard: GMT+0, DST: GMT+1, DST Start: 31/03/2013, DST End: 27/10/2013
. 2013-09-06 14:32:29.471 Login time: 06 September 2013 14:32:29
. 2013-09-06 14:32:29.471 --------------------------------------------------------------------------
. 2013-09-06 14:32:29.471 Session name: xxx.xxx.net (Stored session)
. 2013-09-06 14:32:29.471 Host name: xxx.xxx.net (Port: 990)
. 2013-09-06 14:32:29.471 User name: xxxftp (Password: Yes, Key file: No)
. 2013-09-06 14:32:29.471 Tunnel: No
. 2013-09-06 14:32:29.471 Transfer Protocol: FTP
. 2013-09-06 14:32:29.471 Ping type: C, Ping interval: 30 sec; Timeout: 30 sec
. 2013-09-06 14:32:29.471 Proxy: none
. 2013-09-06 14:32:29.471 FTP: FTPS: Implicit SSL/TLS; Passive: Yes [Force IP: A]; List all: A
. 2013-09-06 14:32:29.471 Session reuse: Yes
. 2013-09-06 14:32:29.471 Local directory: default, Remote directory: /Production/In/Client Reporting/Hot Folder, Update: No, Cache: No
. 2013-09-06 14:32:29.471 Cache directory changes: No, Permanent: Yes
. 2013-09-06 14:32:29.471 DST mode: 1; Timezone offset: 0h 0m
. 2013-09-06 14:32:29.643 Connecting to xxx.xxx.net:990 ...
. 2013-09-06 14:32:29.877 m_pSslLayer changed state from 0 to 1
. 2013-09-06 14:32:29.877 m_pSslLayer changed state from 1 to 2
. 2013-09-06 14:32:29.892 m_pSslLayer changed state from 2 to 4
. 2013-09-06 14:32:29.892 Connected with xxx.xxx.net:990, negotiating SSL connection...
. 2013-09-06 14:32:29.908 SSL_connect: SSLv3 read server hello A
. 2013-09-06 14:32:29.908 SSL_connect: SSLv3 read server certificate A
. 2013-09-06 14:32:29.908 SSL_connect: SSLv3 read server done A
. 2013-09-06 14:32:29.908 SSL_connect: SSLv3 write client key exchange A
. 2013-09-06 14:32:29.908 SSL_connect: SSLv3 write change cipher spec A
. 2013-09-06 14:32:29.908 SSL_connect: SSLv3 write finished A
. 2013-09-06 14:32:29.908 SSL_connect: SSLv3 flush data
. 2013-09-06 14:32:29.939 SSL_connect: SSLv3 read server session ticket A
. 2013-09-06 14:32:29.939 SSL_connect: SSLv3 read finished A
. 2013-09-06 14:32:29.939 Using TLSv1, cipher TLSv1/SSLv3: AES256-SHA, 1024 bit RSA
. 2013-09-06 14:32:29.939 SSL connection established. Waiting for welcome message...
< 2013-09-06 14:32:29.939 220-FileZilla Server version 0.9.41 beta
< 2013-09-06 14:32:29.939 220-written by Tim Kosse (Tim.Kosse@gmx.de)
< 2013-09-06 14:32:29.939 220 Please visit http://sourceforge.net/projects/filezilla/
> 2013-09-06 14:32:29.939 USER xxxftp
< 2013-09-06 14:32:29.939 331 Password required for xxxftp
> 2013-09-06 14:32:29.939 PASS *************
< 2013-09-06 14:32:29.955 230 Logged on
> 2013-09-06 14:32:29.955 SYST
< 2013-09-06 14:32:29.970 215 UNIX emulated by FileZilla
> 2013-09-06 14:32:29.970 FEAT
< 2013-09-06 14:32:29.986 211-Features:
< 2013-09-06 14:32:29.986 MDTM
< 2013-09-06 14:32:29.986 REST STREAM
< 2013-09-06 14:32:29.986 SIZE
< 2013-09-06 14:32:29.986 MLST type*;size*;modify*;
< 2013-09-06 14:32:29.986 MLSD
< 2013-09-06 14:32:29.986 AUTH SSL
< 2013-09-06 14:32:29.986 AUTH TLS
< 2013-09-06 14:32:29.986 PROT
< 2013-09-06 14:32:29.986 PBSZ
< 2013-09-06 14:32:29.986 UTF8
< 2013-09-06 14:32:29.986 CLNT
< 2013-09-06 14:32:29.986 MFMT
< 2013-09-06 14:32:29.986 211 End
> 2013-09-06 14:32:29.986 PBSZ 0
< 2013-09-06 14:32:29.986 200 PBSZ=0
> 2013-09-06 14:32:29.986 PROT P
< 2013-09-06 14:32:30.001 200 Protection level set to P
. 2013-09-06 14:32:30.001 Connected
. 2013-09-06 14:32:30.001 Got reply 1 to the command 1
. 2013-09-06 14:32:30.001 --------------------------------------------------------------------------
. 2013-09-06 14:32:30.001 Using FTP protocol.
. 2013-09-06 14:32:30.001 Doing startup conversation with host.
> 2013-09-06 14:32:30.001 PWD
< 2013-09-06 14:32:30.017 257 "/" is current directory.
. 2013-09-06 14:32:30.017 Got reply 1 to the command 16
. 2013-09-06 14:32:30.017 Changing directory to "/Production/In/Client Reporting/Hot Folder".
> 2013-09-06 14:32:30.017 CWD /Production/In/Client Reporting/Hot Folder
< 2013-09-06 14:32:30.017 250 CWD successful. "/Production/In/Client Reporting/Hot Folder" is current directory.
. 2013-09-06 14:32:30.017 Getting current directory name.
> 2013-09-06 14:32:30.017 PWD
< 2013-09-06 14:32:30.033 257 "/Production/In/Client Reporting/Hot Folder" is current directory.
. 2013-09-06 14:32:30.033 Got reply 1 to the command 16
. 2013-09-06 14:32:30.033 Startup conversation with host finished.
< 2013-09-06 14:32:30.033 Script: Active session: [1] xxxftp@xxx.xxx.net
. 2013-09-06 14:32:30.033 Session upkeep
> 2013-09-06 14:32:30.033 Script: option transfer binary
< 2013-09-06 14:32:30.033 Script: transfer binary
> 2013-09-06 14:32:30.033 Script: lcd "t:\\Client reporting\Equi FTP HotFolder"
< 2013-09-06 14:32:30.033 Script: t:\Client reporting\Equi FTP HotFolder
> 2013-09-06 14:32:30.033 Script: cd /
. 2013-09-06 14:32:30.033 Changing directory to "/".
> 2013-09-06 14:32:30.033 CWD /
< 2013-09-06 14:32:30.048 250 CWD successful. "/" is current directory.
. 2013-09-06 14:32:30.048 Got reply 1 to the command 16
. 2013-09-06 14:32:30.048 Getting current directory name.
> 2013-09-06 14:32:30.048 PWD
< 2013-09-06 14:32:30.064 257 "/" is current directory.
. 2013-09-06 14:32:30.064 Got reply 1 to the command 16
< 2013-09-06 14:32:30.064 Script: /
. 2013-09-06 14:32:30.064 Session upkeep
> 2013-09-06 14:32:30.064 Script: cd "Development/In/Client Reporting/Hot Folder"
. 2013-09-06 14:32:30.064 Changing directory to "Development/In/Client Reporting/Hot Folder".
> 2013-09-06 14:32:30.064 CWD Development/In/Client Reporting/Hot Folder
< 2013-09-06 14:32:30.079 250 CWD successful. "/Development/In/Client Reporting/Hot Folder" is current directory.
. 2013-09-06 14:32:30.079 Got reply 1 to the command 16
. 2013-09-06 14:32:30.079 Getting current directory name.
> 2013-09-06 14:32:30.079 PWD
< 2013-09-06 14:32:30.079 257 "/Development/In/Client Reporting/Hot Folder" is current directory.
< 2013-09-06 14:32:30.079 Script: /Development/In/Client Reporting/Hot Folder
. 2013-09-06 14:32:30.079 Session upkeep
> 2013-09-06 14:32:30.079 Script: put -delete *.*
. 2013-09-06 14:32:30.079 Copying 65 files/directories to remote directory "/Development/In/Client Reporting/Hot Folder"
. 2013-09-06 14:32:30.079 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 0100; Resume: Y (102400); CalcS: No; Mask:
. 2013-09-06 14:32:30.079 TM: B; ClAr: No; CPS: 0; InclM:
. 2013-09-06 14:32:30.079 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2013-09-06 14:32:30.079 File: "facmata.pdf"
. 2013-09-06 14:32:30.142 Copying "facmata.pdf" to remote directory started.
. 2013-09-06 14:32:30.142 Binary transfer mode selected.
. 2013-09-06 14:32:30.142 Starting upload of facmata.pdf
> 2013-09-06 14:32:30.142 TYPE A
< 2013-09-06 14:32:30.157 200 Type set to A
> 2013-09-06 14:32:30.157 PASV
< 2013-09-06 14:32:30.157 227 Entering Passive Mode (168,63,10,127,234,97)
> 2013-09-06 14:32:30.157 MLSD
. 2013-09-06 14:32:30.173 Trying reuse main SSL session ID
. 2013-09-06 14:32:30.173 m_pSslLayer changed state from 0 to 4
< 2013-09-06 14:32:30.189 150 Connection accepted
. 2013-09-06 14:32:30.189 Session ID reused
. 2013-09-06 14:32:30.189 SSL connection established
< 2013-09-06 14:32:30.204 226 Transfer OK
. 2013-09-06 14:32:30.204 m_pSslLayer changed state from 4 to 5
. 2013-09-06 14:32:30.204 type=file;modify=20130705120023;size=102912; 130630_0904FRR_MTD_SOURCE_TRANSACTIONS.xls
. 2013-09-06 14:32:30.204 type=file;modify=20120717093251;size=693485; cbuci52.pdf
. 2013-09-06 14:32:30.204 type=file;modify=20120710051150;size=1511889; cdef.pdf
. 2013-09-06 14:32:30.204 type=file;modify=20071011122135;size=2637841; cds.pdf
. 2013-09-06 14:32:30.204 type=file;modify=20070828114119;size=1778526; cfd.pdf
. 2013-09-06 14:32:30.204 type=file;modify=20110201134741;size=932069; chtavi49.pdf
. 2013-09-06 14:32:30.204 type=file;modify=20110712120145;size=872428; chtavi50.pdf
. 2013-09-06 14:32:30.204 type=file;modify=20120119151300;size=605194; chtavi51.pdf
. 2013-09-06 14:32:30.204 type=file;modify=20120727092128;size=707917; chtavi52.pdf
. 2013-09-06 14:32:30.204 type=file;modify=20120302094123;size=2469714; clientre.pdf
. 2013-09-06 14:32:30.204 type=file;modify=20070620100655;size=4288395; climan.pdf
. 2013-09-06 14:32:30.204 type=file;modify=20120113075826;size=3477747; collaadm.pdf
. 2013-09-06 14:32:30.204 type=file;modify=20120516070830;size=476663; commseri.pdf
. 2013-09-06 14:32:30.204 type=file;modify=20111202115533;size=1466278; commserv.pdf
. 2013-09-06 14:32:30.204 type=file;modify=20100503065918;size=2594387; complmng.pdf
. 2013-09-06 14:32:30.204 type=file;modify=20110816064857;size=2490169; composit.pdf
. 2013-09-06 14:32:30.204 type=file;modify=20110322134607;size=2200482; corpact.pdf
. 2013-09-06 14:32:30.204 type=file;modify=20130906111158;size=12560; CR_COMMENTARY_CLIENTCODE_31MAR2013.docx
. 2013-09-06 14:32:30.204 type=file;modify=20120710051420;size=1620789; csdef.pdf
. 2013-09-06 14:32:30.204 type=file;modify=20120601134215;size=3344773; ctm.pdf
. 2013-09-06 14:32:30.204 type=file;modify=20120228085640;size=448788; dataclup.pdf
. 2013-09-06 14:32:30.204 type=file;modify=20070123161028;size=4632734; dataextr.pdf
. 2013-09-06 14:32:30.204 type=file;modify=20120515101634;size=848495; equit.pdf
. 2013-09-06 14:32:30.204 type=file;modify=20110224141157;size=2471166; euro.pdf
. 2013-09-06 14:32:30.204 type=file;modify=20101230090113;size=5323248; faclm.pdf
. 2013-09-06 14:32:30.204 type=file;modify=20121123154447;size=3210438; facma.pdf
. 2013-09-06 14:32:30.204 type=file;modify=20130906133030;size=294912; facmata.pdf
> 2013-09-06 14:32:30.204 TYPE I
< 2013-09-06 14:32:30.220 200 Type set to I
> 2013-09-06 14:32:30.220 PASV
< 2013-09-06 14:32:30.220 227 Entering Passive Mode (168,63,10,127,234,98)
> 2013-09-06 14:32:30.220 STOR facmata.pdf
< 2013-09-06 14:32:30.251 150 Connection accepted
. 2013-09-06 14:32:30.251 Trying reuse main SSL session ID
. 2013-09-06 14:32:30.251 m_pSslLayer changed state from 0 to 4
. 2013-09-06 14:32:30.267 Session ID reused
. 2013-09-06 14:32:30.267 SSL connection established
< 2013-09-06 14:32:30.797 226 Transfer OK
> 2013-09-06 14:32:30.797 MFMT 20091103191206 facmata.pdf
< 2013-09-06 14:32:30.797 213 modify=20091103191206; /Development/In/Client Reporting/Hot Folder/facmata.pdf
. 2013-09-06 14:32:30.797 Upload successful
. 2013-09-06 14:32:30.797 Got reply 1 to the command 4
. 2013-09-06 14:32:30.813 File: "fap.pdf"
. 2013-09-06 14:32:30.844 Copying "fap.pdf" to remote directory started.
. 2013-09-06 14:32:30.844 Binary transfer mode selected.
. 2013-09-06 14:32:30.844 Starting upload of fap.pdf
> 2013-09-06 14:32:30.844 TYPE I
< 2013-09-06 14:32:30.859 200 Type set to I
> 2013-09-06 14:32:30.859 PASV
< 2013-09-06 14:32:30.859 227 Entering Passive Mode (168,63,10,127,234,99)
> 2013-09-06 14:32:30.859 STOR fap.pdf
< 2013-09-06 14:32:30.891 150 Connection accepted
. 2013-09-06 14:32:30.891 Trying reuse main SSL session ID
. 2013-09-06 14:32:30.906 m_pSslLayer changed state from 0 to 4
. 2013-09-06 14:32:30.922 Session ID reused
. 2013-09-06 14:32:30.922 SSL connection established
< 2013-09-06 14:32:31.561 226 Transfer OK
> 2013-09-06 14:32:31.561 MFMT 20100705071417 fap.pdf
< 2013-09-06 14:32:31.577 213 modify=20100705071417; /Development/In/Client Reporting/Hot Folder/fap.pdf
. 2013-09-06 14:32:31.577 Upload successful
. 2013-09-06 14:32:31.577 Got reply 1 to the command 4
. 2013-09-06 14:32:31.593 File: "fndaccs.pdf"
. 2013-09-06 14:32:31.639 Copying "fndaccs.pdf" to remote directory started.
. 2013-09-06 14:32:31.639 Binary transfer mode selected.
. 2013-09-06 14:32:31.639 Starting upload of fndaccs.pdf
> 2013-09-06 14:32:31.639 TYPE I
< 2013-09-06 14:32:31.655 200 Type set to I
> 2013-09-06 14:32:31.655 PASV
< 2013-09-06 14:32:31.655 227 Entering Passive Mode (168,63,10,127,234,100)
> 2013-09-06 14:32:31.655 STOR fndaccs.pdf
< 2013-09-06 14:32:31.686 150 Connection accepted
. 2013-09-06 14:32:31.686 Trying reuse main SSL session ID
. 2013-09-06 14:32:31.686 m_pSslLayer changed state from 0 to 4
. 2013-09-06 14:32:31.702 Session ID reused
. 2013-09-06 14:32:31.702 SSL connection established
< 2013-09-06 14:32:32.185 226 Transfer OK
> 2013-09-06 14:32:32.185 MFMT 20120430105719 fndaccs.pdf
< 2013-09-06 14:32:32.201 213 modify=20120430105719; /Development/In/Client Reporting/Hot Folder/fndaccs.pdf
. 2013-09-06 14:32:32.201 Upload successful
. 2013-09-06 14:32:32.201 Got reply 1 to the command 4
. 2013-09-06 14:32:32.248 File: "fundadms.pdf"
. 2013-09-06 14:32:32.295 Copying "fundadms.pdf" to remote directory started.
. 2013-09-06 14:32:32.310 Binary transfer mode selected.
. 2013-09-06 14:32:32.310 Starting upload of fundadms.pdf
> 2013-09-06 14:32:32.310 TYPE I
< 2013-09-06 14:32:32.310 200 Type set to I
> 2013-09-06 14:32:32.310 PASV
< 2013-09-06 14:32:32.326 227 Entering Passive Mode (168,63,10,127,234,101)
> 2013-09-06 14:32:32.326 STOR fundadms.pdf
< 2013-09-06 14:32:32.357 150 Connection accepted
. 2013-09-06 14:32:32.357 Trying reuse main SSL session ID
. 2013-09-06 14:32:32.357 m_pSslLayer changed state from 0 to 4
. 2013-09-06 14:32:32.373 Session ID reused
. 2013-09-06 14:32:32.373 SSL connection established
< 2013-09-06 14:32:33.059 226 Transfer OK
> 2013-09-06 14:32:33.059 MFMT 20120425124119 fundadms.pdf
< 2013-09-06 14:32:33.075 213 modify=20120425124119; /Development/In/Client Reporting/Hot Folder/fundadms.pdf
. 2013-09-06 14:32:33.075 Upload successful
. 2013-09-06 14:32:33.075 Got reply 1 to the command 4
. 2013-09-06 14:32:33.122 File: "fundcert.pdf"
. 2013-09-06 14:32:33.137 Copying "fundcert.pdf" to remote directory started.
. 2013-09-06 14:32:33.137 Binary transfer mode selected.
. 2013-09-06 14:32:33.153 Starting upload of fundcert.pdf
> 2013-09-06 14:32:33.153 TYPE I
< 2013-09-06 14:32:33.153 200 Type set to I
> 2013-09-06 14:32:33.153 PASV
< 2013-09-06 14:32:33.168 227 Entering Passive Mode (168,63,10,127,234,102)
> 2013-09-06 14:32:33.168 STOR fundcert.pdf
< 2013-09-06 14:32:33.200 150 Connection accepted
. 2013-09-06 14:32:33.200 Trying reuse main SSL session ID
. 2013-09-06 14:32:33.200 m_pSslLayer changed state from 0 to 4
. 2013-09-06 14:32:33.200 Session ID reused
. 2013-09-06 14:32:33.200 SSL connection established
< 2013-09-06 14:32:34.089 226 Transfer OK
> 2013-09-06 14:32:34.104 MFMT 20100518122012 fundcert.pdf
< 2013-09-06 14:32:34.104 213 modify=20100518122012; /Development/In/Client Reporting/Hot Folder/fundcert.pdf
. 2013-09-06 14:32:34.104 Upload successful
. 2013-09-06 14:32:34.104 Got reply 1 to the command 4
. 2013-09-06 14:32:34.136 File: "fundops.pdf"
. 2013-09-06 14:32:34.182 Copying "fundops.pdf" to remote directory started.
. 2013-09-06 14:32:34.182 Binary transfer mode selected.
. 2013-09-06 14:32:34.182 Starting upload of fundops.pdf
> 2013-09-06 14:32:34.182 TYPE I
< 2013-09-06 14:32:34.198 200 Type set to I
> 2013-09-06 14:32:34.198 PASV
< 2013-09-06 14:32:34.198 227 Entering Passive Mode (168,63,10,127,234,103)
> 2013-09-06 14:32:34.198 STOR fundops.pdf
< 2013-09-06 14:32:34.229 150 Connection accepted
. 2013-09-06 14:32:34.229 Trying reuse main SSL session ID
. 2013-09-06 14:32:34.229 m_pSslLayer changed state from 0 to 4
. 2013-09-06 14:32:34.245 Session ID reused
. 2013-09-06 14:32:34.245 SSL connection established
< 2013-09-06 14:32:35.087 226 Transfer OK
> 2013-09-06 14:32:35.087 MFMT 20120423113750 fundops.pdf
< 2013-09-06 14:32:35.103 213 modify=20120423113750; /Development/In/Client Reporting/Hot Folder/fundops.pdf
. 2013-09-06 14:32:35.103 Upload successful
. 2013-09-06 14:32:35.103 Got reply 1 to the command 4
. 2013-09-06 14:32:35.150 File: "futnfwds.pdf"
. 2013-09-06 14:32:35.196 Copying "futnfwds.pdf" to remote directory started.
. 2013-09-06 14:32:35.196 Binary transfer mode selected.
. 2013-09-06 14:32:35.196 Starting upload of futnfwds.pdf
> 2013-09-06 14:32:35.212 TYPE I
< 2013-09-06 14:32:35.212 200 Type set to I
> 2013-09-06 14:32:35.212 PASV
< 2013-09-06 14:32:35.228 227 Entering Passive Mode (168,63,10,127,234,104)
> 2013-09-06 14:32:35.228 STOR futnfwds.pdf
< 2013-09-06 14:32:35.259 150 Connection accepted
. 2013-09-06 14:32:35.259 Trying reuse main SSL session ID
. 2013-09-06 14:32:35.259 m_pSslLayer changed state from 0 to 4
. 2013-09-06 14:32:35.259 Session ID reused
. 2013-09-06 14:32:35.259 SSL connection established
< 2013-09-06 14:32:36.273 226 Transfer OK
> 2013-09-06 14:32:36.273 MFMT 20110510075650 futnfwds.pdf
< 2013-09-06 14:32:36.288 213 modify=20110510075650; /Development/In/Client Reporting/Hot Folder/futnfwds.pdf
. 2013-09-06 14:32:36.288 Upload successful
. 2013-09-06 14:32:36.288 Got reply 1 to the command 4
. 2013-09-06 14:32:36.335 File: "fx.pdf"
. 2013-09-06 14:32:36.351 Copying "fx.pdf" to remote directory started.
. 2013-09-06 14:32:36.351 Binary transfer mode selected.
. 2013-09-06 14:32:36.351 Starting upload of fx.pdf
> 2013-09-06 14:32:36.351 TYPE I
< 2013-09-06 14:32:36.366 200 Type set to I
> 2013-09-06 14:32:36.366 PASV
< 2013-09-06 14:32:36.382 227 Entering Passive Mode (168,63,10,127,234,96)
> 2013-09-06 14:32:36.382 STOR fx.pdf
< 2013-09-06 14:32:46.850 425 Can't open data connection.
. 2013-09-06 14:32:46.850 Copying files to remote side failed.
. 2013-09-06 14:32:46.850 Got reply 4 to the command 4
* 2013-09-06 14:32:46.850 (ExtException) Copying files to remote side failed.
* 2013-09-06 14:32:46.850 Can't open data connection.
. 2013-09-06 14:32:46.850 Asking user:
. 2013-09-06 14:32:46.850 Error transferring file 'fx.pdf'. ("Copying files to remote side failed.","Can't open data connection.")
< 2013-09-06 14:32:46.850 Script: Error transferring file 'fx.pdf'.
< 2013-09-06 14:32:46.850 Script: Copying files to remote side failed.
< 2013-09-06 14:32:46.850 Can't open data connection.
* 2013-09-06 14:45:11.462 (EScpSkipFile) Error transferring file 'fx.pdf'.
* 2013-09-06 14:45:11.462 Copying files to remote side failed.
* 2013-09-06 14:45:11.462 Can't open data connection.
. 2013-09-06 14:45:11.462 Script: Failed
. 2013-09-06 14:45:11.462 Session upkeep
> 2013-09-06 14:45:11.462 TYPE I
< 2013-09-06 14:45:11.462 200 Type set to I
> 2013-09-06 14:45:11.462 TYPE A
< 2013-09-06 14:45:11.462 200 Type set to A
> 2013-09-06 14:45:11.462 REST 0
< 2013-09-06 14:45:11.462 350 Rest supported. Restarting at 0
> 2013-09-06 14:45:11.462 PWD
< 2013-09-06 14:45:11.462 257 "/Development/In/Client Reporting/Hot Folder" is current directory.
< 2013-09-06 14:45:11.462 421 No-transfer-time exceeded. Closing control connection.
. 2013-09-06 14:45:11.462 m_pSslLayer changed state from 4 to 5
. 2013-09-06 14:45:11.462 Disconnected from server
. 2013-09-06 14:45:11.462 Got reply 1000 to the command 0
< 2013-09-06 14:45:11.462 Script: Lost connection.
< 2013-09-06 14:45:11.462 Script: Disconnected from server
< 2013-09-06 14:45:11.462 No-transfer-time exceeded. Closing control connection.
. 2013-09-06 14:45:11.462 Script: Exit code: 1
Re: Script: Copying files to remote side failed Can't open data
