Where to insert password in batch file
Greasy2
In this command line on the scripting page...
winscp.com /command "option batch abort" "option confirm off" "open sftp://user@example.com" "put examplefile.txt /home/user/" "exit"
Where do you put the password? When I execute the command I connect to my FTP server but it asks me for a password which I can't input in the dos box on my pc for some reason, either by using the paste command or by typing. The cursor doesn't move. Is this normal?
Re: Where to insert password in batch file
Did you find why you were not able to type the password? If not, please send me an email, so I can send you back a debug version of WinSCP to track the problem? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
