How to make WinSCP.exe auto terminted when the program close
jzu
Hong Kong
Hi all,
May I know, is there any way in code level, makes the winscp.exe auto quit after the .net program closed?
I've experience that the winscp.exe remain in memory (via task manager), it is because the .net program force closed.
I've used the "using" statement in .net program and call the dispose() method inside, but it seems the dispose method have not been called.
Jackson
jzu
Hong Kong
Re: How to make WinSCP.exe auto terminted when the program close
https://winscp.net/tracker/1045
Hi prikryl,
Just for my own interested, how do you do that? By using the Windows's API "Job Objects"?
Jackson
Yes.
