Import sites (beta version) unabled
samuel
I would like to import my saved sites from Filezilla. I read your instruction, installed latest beta version, but "Import sites" button is always grayed - I can't use it. I run it on Win8. Can you help?
Thanks!
Re: Import sites (beta version) unabled
WinSCP looks for FileZilla sites in %APPDATA%\FileZilla\sitemanager.xml.
Maybe you have your sites stored elsewhere? Can you find where, so I can improve the import process?
