access wftpd e:\backup root
kle_py
I have a problem accessing a wftpd server. The user of the ftp server has a root directory of E:\backup.
When i try to connect with winscp i get the message:
Unknown directory: /E:/BACKUP/E:/BACKUP
Then the program opens and shows en empty root directory.
Is there some trick to make it work ?
When using the program FileZilla the connection works as a charm.
I would quit using FileZilla if i could make this work.
thanks[/quote]
Re: access wftpd e:\backup root
kle_py
here i attach the log file.
I am using the latest version in the portable version.
WFTPD is version 2.03 32 bit (by Texas Imperial Software)
Description: the log file
I have sent you an email with a development version of WinSCP to address you have used to register on this forum.
Thanks for the log. I can see the problem. I'll try to fix it in later version.
