Imported sessions not recognized after move into folder
hpreusse
I'm pretty sure this is an FAQ. I'm using the import function of winscp to import defined sessions from putty. After this has been done I create a sub-folder in the "Stored Session" list and move the imported sessions into an appropriate sub-folder. When I now re-open the import dialogue box winscp doesn't seem to recognize that the session has just been imported; the check box which marks all not yet imported is selected for the sessions just created (and moved into a sub-folder).
Any ideas? Thanks!
Re: Imported sessions not recognized after move into folder
WinSCP matches the stored sessions/sites by it's name, where a folder name is part of the stored session/site name.
hpreusse
Yes, looks that like. Any chance to have that changed?
Many thanks,
Hilmar
Let's see if more people ask for this.
hpreusse
Posted a new topic into the forum "feature requests". Hope this was OK.
Leora45
Portugal
Hi hpreusse,
I'm not sure if I fully understood the goal of this request.
Is this request for importing different sessions from other clients, like PuTTY or FileZilla, to WinSCP and than this sessions to be recognized by WinSCP ?
Cheers,
Leora
Is this request for importing different sessions from other clients, like PuTTY or FileZilla, to WinSCP and than this sessions to be recognized by WinSCP?
No, this is to recognize sessions which have been imported from putty after they have moved into a subdir in winscp. Can be reproduced easy:
1. Import a session into winscp from putty.
2. Try to re-import it (you'll see that the import tool does not select it by itself, b/c it has been imported already). -> Good
3. No create a subdir in the session list an move the imported session into that subdir.
4. Repeat step #2. You'll notice that the imported session is not recognized and is selected again.
Hilmar
Emma7123
Ireland
Ah, this was the problem that i've been having since yesterday, thanks i just got it sorted there by doing as you mentioned - Lifesaver :D
Emma
