Remote sync – filemask to exclude a subfolder
casual
Amsterdam
I'm trying to use WinSCP (5.1.7 on Windows 7) to set up an automated deployment of a .NET app to an SFTP server (Windows-based shared hosting).
Using the great documentation I was able to get this working except for one part.
I'd like the deployment to ignore a subfolder (e.g. /App_Data/logs/) and all files within.
I've tried to use the exclusion filemask in a dozen different ways but just cannot find the right formula – WinSCP still syncs the subfolder.
This is the command line I use:
winscp /command "option batch abort" "open sftp://login:pwd@server.com/ -hostkey=""ssh-rsa 2048 fingerprint""" "cd /web/content/" "lcd test" "ls" "lls" "synchronize remote -delete -nopermissions -transfer=binary -filemask=""|App_Data/logs/; App_Data/logs/*.*; App_Data/logs/*/*.*""" "close" "exit"
Result (console output) is:
Comparing...
Local 'C:\...\test\App_Data\logs' => Remote '/web/content/App_Data/logs'
Synchronizing...
'/web/content/App_Data/logs/logs.txt' deleted
C:\...\logs\logs2.txt     |          0 KiB |    0.0 KiB/s | binary |   0%
pogster123
Combining include and exclude file masks
Hi Martin,
I have a similar situation where I am trying to exclude a subdirectory when calling getfile and putfile. However I am slightly confused by the pipe | that starts the exclusion portion in the filemask.
My PowerShell script is currently working perfectly using pipe as a separator for an INCLUSION filemask designed to get and push certain file types:
$mask = "*.txt|*.ps1|*.bat"
$files = $session.EnumerateRemoteFiles($remotepath, $mask,
    WinSCP.EnumerationOptions]::AllDirectories)
So how can I add a subdirectory EXCLUSION to the existing mask? I have tried
$mask = "*.txt;*.ps1;*.bat|*/", or even just the inclusion file mask with the semicolon separator alone $mask = "*.txt;*.ps1", just to see if the semicolon works.
Files are not getting downloaded with this approach.
Your help would be much appreciated. Thank you for everything you do.
Re: Combining include and exclude file masks
The mask argument of Session.EnumerateRemoteFiles supports only simple Windows wildcards. Not exclusion masks.
https://winscp.net/eng/docs/library_session_enumerateremotefiles#mask
With the pipe as a mask separator, you have only hit an edge case of internal mask processing implementation. It should have never worked this way. It's actually a bug.
If you do not want to list subdirectories, replace [WinSCP.EnumerationOptions]::AllDirectories with [WinSCP.EnumerationOptions]::None.
