Multiple Files
Caveo
Multiple Files
I am having an issue with my script not picking up multiple files. It will only grab the first file in the directory and then stop. How do I need to modify this script to upload multiple files? The files have different extensions which is why I used the mask filename*.
option batch on
open sftp://username@server.com -hostkey="ssh-rsa 1024 AA:AA:AA"
cd /incoming/test
put E:\folder\Filename*
Re: Multiple Files
Your code looks ok. Please attach a full log file showing the problem (using the latest version of WinSCP).
Caveo
Re: Multiple Files
The log is attached.
Line 70 in the log says "Copying 3 files/directories to remote directory" which is correct. There were 3 files when this was ran.
Line 93 says "Upload of file 'PosPay_1005_08202013_095943.txt' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn on 'Ignore permission errors' option. ("Permission denied."
Would these errors cause the script to abort after the first file is transferred?
Caveo
Re: Multiple Files
I answered my own question. The permission errors were causing the upload script to close.
This script works:
option batch on
cd /incoming/test
put -nopermissions -nopreservetime E:\folder\Filename*
Thank you for your assistance in directing me to the log files.
