Error Downloading File - Wildcard Issue?
JasonRkr
Sunny Southern California
Group,
I'm receiving a file not found error when trying to download a file using a wildcard in the name. However, when I use the full file name it works without issue. Below is a section of the DebugLog file in the hopes it may provide additional detail. Also, the server I'm downloading from is running AIX 6.
<session xmlns="https://winscp.net/schema/session/1.0" name="qcupload@vm6klab1" start="2013-08-14T21:07:07.742Z">
<group name="open -hostkey=&quot;ssh-rsa 2048 0e:2b:76:24:bf:50:e7:29:f5:01:2b:e6:59:16:ea:10&quot; -timeout=15 sftp://qcupload:***@vm6klab1" start="2013-08-14T21:07:08.539Z">
</group>
<group name="stat -- &quot;/U/softprint/FTP14*.x&quot;" start="2013-08-14T21:07:08.664Z">
<stat>
<filename value="/U/softprint/FTP14*.x" />
<result success="false">
<message>Can't get attributes of file '/U/softprint/FTP14*.x'.</message>
<message>No such file or directory.
Error code: 2
Error message from server: No such file
Request code: 7</message>
</result>
</stat>
<failure>
Error code: 2
</failure>
</group>
<group name="exit" start="2013-08-14T21:07:08.789Z">
</group>
</session>
Thank you,
Jason
Ok, but I suppose you set the fileName to FTP14*.x.
As the example, you refer to, calls session.FileExists(remotePath) before calling session.GetFiles(remotePath, localPath), it fails. You probably do not want the check at all. Just remove it.
Also note that the example does not use wildcards, nor mentions anywhere that you can use wildcards for it.
Anyway this is really just an code sample. If you want its functionality, including wildcard support, use the simple code mentioned in comments:
// You can achieve the same using:
session.SynchronizeDirectories(
    SynchronizationMode.Local, localPath, remotePath, false, false, SynchronizationCriteria.Time,
    new TransferOptions { IncludeMask = fileName }).Check();
