.net bacimageformatexception was unhandled
xyz999
aloha
Am getting the below error, can anyone assist on how to correct?
BadImageFormatException was unhandled
Could not load file or assembly 'WinSCP, Version=1.0.7.3394, Culture=neutral, PublicKeyToken=b5f19f5762436b89' or one of its dependencies. The module was expected to contain an assembly manifest
-Installed winscp 5.1.7
-.Net assembly/com library
-added reference in .net solution to winscpnet.dll (renamed)
-included winscp.exe in \bin\debug folder
Thanks in advance for your help!
xyz999
aloha
See below. It is failing immediately when I attempt to instantiate sessionoptions.
thanks for your help!
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Text;
using System.Windows.Forms;
using WinSCP;
namespace RobertUtility
public partial class FrmSftp : Form
public FrmSftp()
InitializeComponent();
private void FrmSftp_Load(object sender, EventArgs e)
private void button1_Click(object sender, EventArgs e)
SessionOptions sessionOptions = new SessionOptions();
//int intValue = 0;
//WinSCPCls sftp = new WinSCPCls();
//intValue = sftp.MainTest ();
Re: .net bacimageformatexception was unhandled
Please try again with a blank project. I suppose you've done something wrong. But it's difficult to tell what. There's too many possibilities.
