WinSCP360
KurĐ+
WinSCP360
I have a problem with new 3.6 version
I have 2 configured connections with two hosts.
The 1st connection doesn't use proxy server. The 2nd does. The problem ist with the 2nd connection, when I click login i get an error:
Assertion failed: frontend, file D:\Martin\Projekty\WinSCP2\core\net.cpp, line 64
and than
Abnormal program termination
sometime i get also an error:
Assertion failed: Configuration, file D:\Martin\Projekty\WinSCP2\core\SecureShell.cpp, line 978
If you need more info, let me know, please.[/code]
KurD+
More info:
Log:
. WinSCP Version 3.6.0 (Build 217) (OS 5.0.2195 Service Pack 4)
. Login time: Freitag, 7. Mai 2004 13:55:36
. Session name: Home Compression
. Host name: **************** (Port: 443)
. User name: ******** (Password: Yes, Key file: No)
. Transfer Protocol: SCP
. SSH protocol version: 2 only; Compression: Yes
. Agent forwarding: No; TIS/CryptoCard: No; KI: Yes
. Ping type: N, Ping interval: 60 sec; Timeout: 15 sec
. SSH Bugs: -,-,-,-,-,-,-,-,
. Proxy: HTTP
. HostName: ********* (Port: 3128); Username: ; Passwd: No
. Shell: /bin/sh, EOL: 0
. Local directory: E:\, Remote directory: /cygdrive, Update: No, Cache: Yes
. Cache directory changes: Yes, Permanent: Yes
. Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. Looking up host "*************"
. Connecting to ************** port 443
* (EAccessViolation) EAccessViolation
Re: WinSCP360
Have exact the same prob - any hints yet ? - BTW. MP your prog is a Genius Brain dump - what would we all do without it ? :D
After testing new 3.6.0 always the above error occurs.
Win XP Pro system, and only the file.exe downloaded, not complete new install.
Greets Ron
Re: WinSCP360
There is no help. It is a bug. I have fixed it already. Please wait for the next release (few days)
Or send an email to me and I'll send you back the fixed version. I would like to have it tested before release (I do not have any proxy to test it myself). This of course applis to KurD+ as well.
KurD+
So I've tested the new version, it works very well with proxy (HTTP Proxy, I couldn't test with other type of proxy server).
Another question or actually two, if I have two transfers in background and I decide to delete one transfer it's working, but if I have one background transfer and I start second transfer (but not background) and then I decide to delete the "nobackground" transfer, winscp disconnect from server so the background transfer is also disconnected, is this feature from design or some type of bug?
2. I think, it would be nice to see also transfer rate in the background transfers window, not only amount of data transfered. It's only a suggesion.
Best Wishes
It is by design. But it happens only for SCP protocol. With SFTP you may cancel the transfer without closing the whole connection. Personally I do not use SCP anymore, so until now I even haven't realized the implication you describe.
I consider that.
frodet
SOCKS proxy is not working
Seems like this is much of the same, but with socks (socks5) instead.
. WinSCP Version 3.6.1 (Build 221) (OS 5.1.2600 Service Pack 1)
. Login time: 14. mai 2004 14:06:35
. Session name: ft
. Host name: xxxxxx.net (Port: 22)
. User name: ft (Password: Yes, Key file: No)
. Transfer Protocol: SFTP (SCP)
. Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. Proxy: SOCKS5
. HostName: proxy.xx (Port: 1080); Username: ; Passwd: No
. Shell: default, EOL: 0
. Local directory: default, Remote directory: home, Update: No, Cache: Yes
. Looking up host "xxxxxx.net"
* (ESshFatal) gethostbyname: unknown error
Re: SOCKS proxy is not working
I'm sorry, but I do not know how to help you with this :-(
Did you specify on proxy settings:
"Do DNS name lookup at proxy end": YES ?
Thanks. Seems that did the trick! :D
You welcome:)
KurD+
