Session in powershell
Fady01
I would like to know how I can call a session that i have already register in the winscp GUI
All exemple that I found require to spefify the session configuration in the powershell script :
# Setup session options
$sessionOptions.HostName = "example.com"
$sessionOptions.UserName = "user"
$sessionOptions.Password = "mypassword"
$sessionOptions.SshHostKeyFingerprint = "ssh-rsa 1024 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
try
# Connect
Any help would be appreciate
Re: Session in powershell
You cannot (at least not in any documented and reliable way), the assembly by purpose runs independently from the GUI configuration.
