Problems with SFTP and empty directories
jjames55
Hi i've just upgraded to 5.1.6, and are still seeing the problems like described in:
https://winscp.net/tracker/706
When loggin in to a FTP server with an empty directory, i get the below.
. 2013-08-12 17:00:16.024 --------------------------------------------------------------------------
. 2013-08-12 17:00:16.040 Connecting to XXX ...
. 2013-08-12 17:00:16.071 Connected with XXX, negotiating SSL connection...
< 2013-08-12 17:00:16.071 XXX. Welcome
> 2013-08-12 17:00:16.071 AUTH SSL
< 2013-08-12 17:00:16.118 234 AUTH Command OK. Initializing SSL connection.
. 2013-08-12 17:00:16.649 SSL connection established. Waiting for welcome message...
> 2013-08-12 17:00:16.649 USER XXX
< 2013-08-12 17:00:16.665 331 Password required for XXX.
> 2013-08-12 17:00:16.665 PASS **********
< 2013-08-12 17:00:16.681 230 Login OK. Proceed.
> 2013-08-12 17:00:16.681 SYST
< 2013-08-12 17:00:16.681 215 UNIX Type: L8
> 2013-08-12 17:00:16.681 FEAT
< 2013-08-12 17:00:16.696 211-Features supported:
< 2013-08-12 17:00:16.696 COMB target;source_list
< 2013-08-12 17:00:16.696 REST STREAM
< 2013-08-12 17:00:16.696 SIZE
< 2013-08-12 17:00:16.696 MDTM
< 2013-08-12 17:00:16.696 XCRC filename;start;end
< 2013-08-12 17:00:16.696 SSCN
< 2013-08-12 17:00:16.696 MLST Size*;Modify*;Create;Type*;Unique;Perm*;Lang;Media-Type;CharSet;
< 2013-08-12 17:00:16.696 MODE Z
< 2013-08-12 17:00:16.696 XNOP
< 2013-08-12 17:00:16.696 211 END
> 2013-08-12 17:00:16.696 PBSZ 0
< 2013-08-12 17:00:16.696 200 PBSZ Command OK. Protection buffer size set to 0.
> 2013-08-12 17:00:16.696 PROT P
< 2013-08-12 17:00:16.712 200 PROT Command OK. Using Private data connection
. 2013-08-12 17:00:16.712 Connected
. 2013-08-12 17:00:16.712 --------------------------------------------------------------------------
. 2013-08-12 17:00:16.712 Using FTP protocol.
. 2013-08-12 17:00:16.712 Doing startup conversation with host.
> 2013-08-12 17:00:16.712 PWD
< 2013-08-12 17:00:16.728 257 "/" is current folder.
. 2013-08-12 17:00:16.728 Getting current directory name.
. 2013-08-12 17:00:16.728 Startup conversation with host finished.
< 2013-08-12 17:00:16.728 Script: Active session: [1] XXX
> 2013-08-12 17:00:16.728 Script: option transfer binary
< 2013-08-12 17:00:16.728 Script: transfer binary
> 2013-08-12 17:00:16.728 Script: option batch abort
< 2013-08-12 17:00:16.728 Script: batch abort
> 2013-08-12 17:00:16.728 Script: option confirm off
< 2013-08-12 17:00:16.728 Script: confirm off
> 2013-08-12 17:00:16.728 Script: lcd f:\XXX
< 2013-08-12 17:00:16.728 Script: f:\XXX
> 2013-08-12 19:00:43.092 Script: get A* -delete
. 2013-08-12 19:00:43.092 Retrieving directory listing...
> 2013-08-12 19:00:43.092 TYPE A
< 2013-08-12 19:00:43.092 200 Type set to A.
> 2013-08-12 19:00:43.092 PASV
< 2013-08-12 19:00:43.124 227 Entering Passive Mode (212,130,240,223,109,96).
. 2013-08-12 19:00:43.124 Error retrieving server address, cannot test if address is routable
> 2013-08-12 19:00:43.124 MLSD
< 2013-08-12 19:00:43.155 150 Opening BINARY mode data connection for MLSD /.
. 2013-08-12 19:00:43.171 SSL connection established
. 2013-08-12 19:00:43.186 Could not retrieve directory listing
< 2013-08-12 19:00:43.264 226 Transfer complete. 0 bytes transferred. 0 bps.
. 2013-08-12 19:00:43.264 Asking user:
. 2013-08-12 19:00:43.264 Error listing directory '/'. ("Error retrieving server address, cannot test if address is routable","Could not retrieve directory listing","Transfer complete. 0 bytes transferred. 0 bps.")
< 2013-08-12 19:00:43.264 Script: Error listing directory '/'.
< 2013-08-12 19:00:43.264 Script: Error retrieving server address, cannot test if address is routable
< 2013-08-12 19:00:43.264 Could not retrieve directory listing
< 2013-08-12 19:00:43.264 Transfer complete. 0 bytes transferred. 0 bps.
. 2013-08-12 19:00:43.264 Script: Failed
. 2013-08-12 19:00:43.264 Script: Exit code: 1
. 2013-08-12 19:00:43.264 Disconnected from server
With files there it works fine... This is across several FTP servers
Any ideas???
regards,
Jesper
Re: Problems with SFTP and empty directories
Please attach a complete session log file using the latest beta version.
Here you go, same problem it seems.
. 2013-08-14 10:29:16.332 --------------------------------------------------------------------------
. 2013-08-14 10:29:16.332 WinSCP Version 5.2.3 (Build 3436) (OS 5.2.3790 Service Pack 2)
. 2013-08-14 10:29:16.347 Configuration: C:\Program Files\WinSCPbeta\WinSCP.ini
. 2013-08-14 10:29:16.363 Local account: XXX
. 2013-08-14 10:29:16.363 Working directory: C:\Program Files\WinSCPbeta
. 2013-08-14 10:29:16.363 Process ID: 7768
. 2013-08-14 10:29:16.363 Command-line: "C:\Program Files\WinSCPbeta\WinSCP.exe" /console=523 /consoleinstance=_10312_336 "/script=XXX" "/log=a.log"
. 2013-08-14 10:29:16.363 Time zone: Current: GMT+2, Standard: GMT+1, DST: GMT+2, DST Start: 31-03-2013, DST End: 27-10-2013
. 2013-08-14 10:29:16.363 Login time: 14. august 2013 10:29:16
. 2013-08-14 10:29:16.363 --------------------------------------------------------------------------
. 2013-08-14 10:29:16.363 Script: Retrospectivelly logging previous script records:
> 2013-08-14 10:29:16.363 Script: open XXX
. 2013-08-14 10:29:16.363 Session name: XXX (Site)
. 2013-08-14 10:29:16.363 Host name: XXX (Port: 21)
. 2013-08-14 10:29:16.363 User name: XXX (Password: Yes, Key file: No)
. 2013-08-14 10:29:16.363 Tunnel: No
. 2013-08-14 10:29:16.363 Transfer Protocol: FTP
. 2013-08-14 10:29:16.363 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2013-08-14 10:29:16.363 Proxy: SOCKS4
. 2013-08-14 10:29:16.363 HostName: 10.11.76.3 (Port: 1080); Username: ; Passwd: No
. 2013-08-14 10:29:16.363 FTP: FTPS: Explicit SSL; Passive: Yes [Force IP: A]; MLSD: A [List all: A]
. 2013-08-14 10:29:16.363 Session reuse: Yes
. 2013-08-14 10:29:16.363 TLS/SSL versions: SSLv2-TLSv1.2
. 2013-08-14 10:29:16.363 Local directory: default, Remote directory: home, Update: No, Cache: No
. 2013-08-14 10:29:16.363 Cache directory changes: No, Permanent: No
. 2013-08-14 10:29:16.363 DST mode: 1; Timezone offset: 0h 0m
. 2013-08-14 10:29:16.379 Connecting to XXX ...
. 2013-08-14 10:29:16.379 Proxy layer changed state from unconnected to connecting
. 2013-08-14 10:29:16.379 TLS layer changed state from unconnected to connecting
. 2013-08-14 10:29:16.379 Proxy layer changed state from connecting to connected
. 2013-08-14 10:29:16.379 TLS layer changed state from connecting to connected
. 2013-08-14 10:29:16.379 Connected with XXX, negotiating TLS connection...
< 2013-08-14 10:29:16.394 220 XXX
> 2013-08-14 10:29:16.394 AUTH SSL
< 2013-08-14 10:29:16.582 234 AUTH Command OK. Initializing SSL connection.
. 2013-08-14 10:29:16.863 TLS connect: SSLv3 read server hello A
. 2013-08-14 10:29:16.863 TLS connect: SSLv3 read server certificate A
. 2013-08-14 10:29:16.863 TLS connect: SSLv3 read server done A
. 2013-08-14 10:29:16.863 TLS connect: SSLv3 write client key exchange A
. 2013-08-14 10:29:16.863 TLS connect: SSLv3 write change cipher spec A
. 2013-08-14 10:29:16.863 TLS connect: SSLv3 write finished A
. 2013-08-14 10:29:16.863 TLS connect: SSLv3 flush data
. 2013-08-14 10:29:16.894 TLS connect: SSLv3 read server session ticket A
. 2013-08-14 10:29:16.894 TLS connect: SSLv3 read finished A
. 2013-08-14 10:29:16.894 Using TLSv1, cipher TLSv1/SSLv3: AES256-SHA, 2048 bit RSA
. 2013-08-14 10:29:16.894 TLS connection established. Waiting for welcome message...
> 2013-08-14 10:29:16.894 USER XXX
< 2013-08-14 10:29:16.894 331 Password required for XXX.
> 2013-08-14 10:29:16.894 PASS **********
< 2013-08-14 10:29:16.910 230 Login OK. Proceed.
> 2013-08-14 10:29:16.910 SYST
< 2013-08-14 10:29:16.926 215 UNIX Type: L8
> 2013-08-14 10:29:16.926 FEAT
< 2013-08-14 10:29:16.926 211-Features supported:
< 2013-08-14 10:29:16.926 COMB target;source_list
< 2013-08-14 10:29:16.926 REST STREAM
< 2013-08-14 10:29:16.926 SIZE
< 2013-08-14 10:29:16.926 MDTM
< 2013-08-14 10:29:16.926 XCRC filename;start;end
< 2013-08-14 10:29:16.926 SSCN
< 2013-08-14 10:29:16.926 MLST Size*;Modify*;Create;Type*;Unique;Perm*;Lang;Media-Type;CharSet;
< 2013-08-14 10:29:16.926 XNOP
< 2013-08-14 10:29:16.926 211 END
> 2013-08-14 10:29:16.926 PBSZ 0
< 2013-08-14 10:29:16.941 200 PBSZ Command OK. Protection buffer size set to 0.
> 2013-08-14 10:29:16.941 PROT P
< 2013-08-14 10:29:16.941 200 PROT Command OK. Using Private data connection
. 2013-08-14 10:29:16.941 Connected
. 2013-08-14 10:29:16.941 Got reply 1 to the command 1
. 2013-08-14 10:29:16.941 --------------------------------------------------------------------------
. 2013-08-14 10:29:16.941 Using FTP protocol.
. 2013-08-14 10:29:16.941 Doing startup conversation with host.
> 2013-08-14 10:29:16.941 PWD
< 2013-08-14 10:29:16.957 257 "/" is current folder.
. 2013-08-14 10:29:16.957 Got reply 1 to the command 16
. 2013-08-14 10:29:16.957 Getting current directory name.
. 2013-08-14 10:29:16.957 Startup conversation with host finished.
< 2013-08-14 10:29:16.957 Script: Active session: [1] XXX
. 2013-08-14 10:29:16.957 Session upkeep
> 2013-08-14 10:29:16.957 Script: option transfer binary
< 2013-08-14 10:29:16.957 Script: transfer binary
> 2013-08-14 10:29:16.957 Script: option batch abort
< 2013-08-14 10:29:16.957 Script: batch abort
> 2013-08-14 10:29:16.957 Script: option confirm off
< 2013-08-14 10:29:16.957 Script: confirm off
> 2013-08-14 10:29:16.957 Script: lcd XXX
< 2013-08-14 10:29:16.957 Script: XXX
> 2013-08-14 10:29:16.957 Script: get A* -delete
. 2013-08-14 10:29:16.957 Retrieving directory listing...
> 2013-08-14 10:29:16.957 TYPE A
< 2013-08-14 10:29:16.972 200 Type set to A.
> 2013-08-14 10:29:16.972 PASV
< 2013-08-14 10:29:16.972 227 Entering Passive Mode (212,130,240,223,109,96).
. 2013-08-14 10:29:16.972 Error retrieving server address, cannot test if address is routable
> 2013-08-14 10:29:16.972 MLSD
. 2013-08-14 10:29:16.972 Proxy layer changed state from unconnected to connecting
. 2013-08-14 10:29:16.988 Proxy layer changed state from connecting to connected
< 2013-08-14 10:29:16.988 150 Opening BINARY mode data connection for MLSD /.
. 2013-08-14 10:29:17.004 Trying reuse main TLS session ID
. 2013-08-14 10:29:17.004 TLS layer changed state from none to connected
. 2013-08-14 10:29:17.019 Session ID reused
. 2013-08-14 10:29:17.019 TLS connection established
. 2013-08-14 10:29:17.035 TLS layer changed state from connected to aborted
. 2013-08-14 10:29:17.035 Could not retrieve directory listing
. 2013-08-14 10:29:17.035 Got reply 4 to the command 2
< 2013-08-14 10:29:17.082 226 Transfer complete. 0 bytes transferred. 0 bps.
. 2013-08-14 10:29:17.082 Asking user:
. 2013-08-14 10:29:17.082 Error listing directory '/'. ("Error retrieving server address, cannot test if address is routable","Could not retrieve directory listing","Transfer complete. 0 bytes transferred. 0 bps.")
< 2013-08-14 10:29:17.082 Script: Error listing directory '/'.
< 2013-08-14 10:29:17.097 Script: Error retrieving server address, cannot test if address is routable
< 2013-08-14 10:29:17.097 Could not retrieve directory listing
< 2013-08-14 10:29:17.097 Transfer complete. 0 bytes transferred. 0 bps.
. 2013-08-14 10:29:17.097 Script: Failed
. 2013-08-14 10:29:17.097 Session upkeep
. 2013-08-14 10:29:17.097 Script: Exit code: 1
. 2013-08-14 10:29:17.097 Got reply 1004 to the command 2
. 2013-08-14 10:29:17.097 Disconnected from server
Any chance of getting a test account on your server?
No unfortunately i don't think so. I can ask.
If not, can you please at least attach a relevant part of server's log?
jjames55
Here is what i got:
2013-08-19 13:01:51 <IP-Address Masked> 21 ControlChannelOpened - - 0 0 0 0 ed10ca22-d9cd-4636-a318-d2a4e3075965 -
2013-08-19 13:01:51 <IP-Address Masked> 21 AUTH SSL 234 0 0 22 10 ed10ca22-d9cd-4636-a318-d2a4e3075965 -
2013-08-19 13:01:51 <IP-Address Masked> 21 USER XXX 331 0 0 69 17 ed10ca22-d9cd-4636-a318-d2a4e3075965 -
2013-08-19 13:01:51 <IP-Address Masked> 21 PASS *** 230 0 0 362 16 ed10ca22-d9cd-4636-a318-d2a4e3075965 /
2013-08-19 13:01:51 <IP-Address Masked> 21 SYST - 215 0 0 53 6 ed10ca22-d9cd-4636-a318-d2a4e3075965 -
2013-08-19 13:01:51 <IP-Address Masked> 21 FEAT - 211 0 0 313 6 ed10ca22-d9cd-4636-a318-d2a4e3075965 -
2013-08-19 13:01:51 <IP-Address Masked> 21 OPTS UTF8+ON 200 0 0 85 14 ed10ca22-d9cd-4636-a318-d2a4e3075965 -
2013-08-19 13:01:51 <IP-Address Masked> 21 PBSZ 0 200 0 0 69 8 ed10ca22-d9cd-4636-a318-d2a4e3075965 -
2013-08-19 13:01:51 <IP-Address Masked> 21 PROT P 200 0 0 69 8 ed10ca22-d9cd-4636-a318-d2a4e3075965 -
2013-08-19 13:01:51 <IP-Address Masked> 21 PWD - 257 0 0 69 5 ed10ca22-d9cd-4636-a318-d2a4e3075965 -
2013-08-19 13:01:51 <IP-Address Masked> 21 CWD \ 250 0 0 69 7 ed10ca22-d9cd-4636-a318-d2a4e3075965 /
2013-08-19 13:01:51 <IP-Address Masked> 21 CWD /XXX 250 0 0 69 14 ed10ca22-d9cd-4636-a318-d2a4e3075965 /XXX
2013-08-19 13:01:51 <IP-Address Masked> 21 TYPE A 200 0 0 53 8 ed10ca22-d9cd-4636-a318-d2a4e3075965 -
2013-08-19 13:01:51 <IP-Address Masked> 21 PASV - 227 0 0 85 6 ed10ca22-d9cd-4636-a318-d2a4e3075965 -
2013-08-19 13:01:52 <IP-Address Masked> 2046 DataChannelOpened - - 0 0 0 0 ed10ca22-d9cd-4636-a318-d2a4e3075965 -
2013-08-19 13:01:52 <IP-Address Masked> 2046 DataChannelClosed - - 0 0 37 204 ed10ca22-d9cd-4636-a318-d2a4e3075965 -
2013-08-19 13:01:52 <IP-Address Masked> 21 LIST -a 226 0 0 159 213 ed10ca22-d9cd-4636-a318-d2a4e3075965 /XXX
2013-08-19 13:01:52 <IP-Address Masked> 21 TYPE A 200 0 0 53 8 ed10ca22-d9cd-4636-a318-d2a4e3075965 -
2013-08-19 13:01:52 <IP-Address Masked> 21 PASV - 227 0 0 85 6 ed10ca22-d9cd-4636-a318-d2a4e3075965 -
2013-08-19 13:01:52 <IP-Address Masked> 2047 DataChannelOpened - - 0 0 0 0 ed10ca22-d9cd-4636-a318-d2a4e3075965 -
2013-08-19 13:01:52 <IP-Address Masked> 2047 DataChannelClosed - - 0 0 37 204 ed10ca22-d9cd-4636-a318-d2a4e3075965 -
2013-08-19 13:01:52 <IP-Address Masked> 21 LIST - 226 0 0 159 210 ed10ca22-d9cd-4636-a318-d2a4e3075965 /XXX
2013-08-19 13:01:52 <IP-Address Masked> 21 ControlChannelClosed - - 0 0 5248 1221 ed10ca22-d9cd-4636-a318-d2a4e3075965 -
In your WinSCP log I can see WinSCP using MLSD command, while in the server's log, there's LIST -a. So it does not seem to be a corresponding log.
Also, can you send me an email, so I can send you back a debug version of WinSCP to track the problem? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
