Retrieve Exit Code from Session.ExecuteCommand
mxcolin
California
I'm using ExecuteCommand on the Session class to call a command remotely however I cannot get at the exit code?
CommandExecutionResult result = session.ExecuteCommand(command.Executable + " " + command.Arguments);
Will throw a SessionRemoteException if the command fails but there's no way to know what the exit code is?
Colin
mxcolin wrote:
Any plans for adding this in anytime soon?
Will consider it. Meanwhile you can dump the exit code to the command output and parse it out yourself.
