Stored Session Copy Paste Menu?
geonspapa
always thanks you.
i use Stored Session menu. and vmware test.
Connent to server, i always new button.
Its server info is just different ip address.
i want connection session Copy & paste. and modify ip address only.
Re: Stored Session Copy Paste Menu?
You can save a stored session without host name. Then, if you double-click it on Login dialog, it does not connect, but just loads all the session settings. You then just fill in the hostname and click Login.
