[REQUEST]New column "Finished" on Queue List
braykov
This columns should be empty on waiting and during transfer.
After a completed transfer it should show the exact time the transfer finished successfully.
If the transfer failed it can show either "Failed" or be empty.
I need this to know whether the document I am editing has been saved on the server and whether it was successful and when it was finished.
So I know when I can use/execute (if it is a script file).
Re: [REQUEST]New column "Finished" on Queue List
If the transfer failed, you will see an error or prompt icon next to the transfer. On success the transfer turns gray and goes away eventually.
I believe this is the indication you ask for.
