WinSCP 3.6 error
tombarry
WinSCP 3.6 error
After installing 3.6, i have noticed that the client fails every single time i connect to a server in the following way: After showing the connection messages, the application promptly dissapears from the task bar, and in Task Manager, WinSCP3.exe is show as using 96% of the avalible CPU load.
This happens every single time without fail, so i have been forced to downgrade to 3.5.6.
I am running windows xp professional sp1.
Re: WinSCP 3.6 error
It maybe some unusual configuration. If you can work with Windows registry, please export following key and send it to me by email:
[HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration]
If you do not know how to do it, type following command on command-line (or to Start/Run):
regedit /s /e:a c:\winscpconfig.reg "HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration"
It will create file c:\winscpconfig.reg
There are no passwords stored in this key!
Desummoner
Catched!
Same cause, same version (WinSCP 3.6 beta multilanguage installation package).
Cleaning up all five places solves problem.
Here is WinSCP3.ini, which 100% causes strange effects:
[Configuration\Interface]
RandomSeedFile=C:%5CDocuments%20and%20Settings%5CGringo%5Cwinscp.RND
ConfirmOverwriting=1
CopyParamDialogExpanded=1
ErrorDialogExpanded=1
ContinueOnError=0
SynchronizeParams=3
QueueTransfersLimit=1
QueueAutoPopup=1
PuttySession=WinSCP%20temporary%20session
PuttyPath=D:%5CApps%5CPuTTY%200.54%5CPUTTY.EXE
IgnoreCancelBeforeFinish=30.12.1899 0:00:03
Interface=1
ShowAdvancedLoginOptions=1
CopyOnDoubleClick=0
CopyOnDoubleClickConfirmation=0
DDAllowMove=0
DDAllowMoveInit=0
DDTransferConfirmation=1
DDTemporaryDirectory=
DDWarnLackOfTempSpace=1
DDWarnLackOfTempSpaceRatio=1,1
DeleteToRecycleBin=1
DimmHiddenFiles=1
SelectDirectories=0
SelectMask=%2A.%2A
ShowHiddenFiles=1
ShowInaccesibleDirectories=1
ConfirmDeleting=1
ConfirmClosingSession=1
ConfirmExitOnCompletion=1
AutoStartSession=
UseLocationProfiles=0
ForceDeleteTempFolder=1
LocaleSafe=1033
DDExtEnabled=1
DDExtTimeout=1000
DDExtCopySlipTimeout=100
DefaultDirIsHome=1
[Configuration\Interface\CopyParam]
AddXToDirectories=1
Masks=%2A.%2Ahtml;%20%2A.htm;%20%2A.txt;%20%2A.php%2A;%20%2A.cgi;%20%2A.c;%20%2A.cpp;%20%2A.h;%20%2A.pas;%20%2A.bas;%20%2A.tex;%20%2A.pl;%20.htaccess;%20%2A.xtml;%20%2A.css;%20%2A.cfg;%20%2A.ini;%20%2A.sh;%20%2A.xml
FileNameCase=0
PreserveReadOnly=1
PreserveTime=1
PreserveRights=1
Text=rw-r-----
TransferMode=0
ResumeSupport=1
ResumeThreshold=102400
ReplaceInvalidChars=1
LocalInvalidChars=/%5C:%2A%3F"<>|
CalculateSize=1
[Configuration\Logging]
Logging=0
LogFileName=
LogFileAppend=1
LogWindowLines=100
LogView=0
LogWindowOnStartup=1
LogWindowParams=-1;-1;500;400
[Configuration\Interface\Editor]
Editor=0
ExternalEditor=notepad.exe%20!.!
ExternalEditorText=1
FontName=Courier%20New
FontHeight=-12
FontStyle=0
FontCharset=1
WordWrap=0
FindText=
ReplaceText=
FindMatchCase=0
FindWholeWord=0
[Configuration\Interface\QueueView]
Height=110
Layout=70,170,170,80,80
Show=0
ToolBar=1
[Configuration\Interface\Explorer]
CoolBarLayout=5,1,0,140,6;3,0,0,127,5;4,1,0,490,4;6,0,0,196,3;2,1,1,634,2;1,1,0,638,1;0,1,1,634,0
DirViewParams=0;1;0|150,1;70,1;101,1;79,1;62,1;55,1;20,0|0;1;2;3;4;5;6
LastLocalTargetDirectory=C:%5CDocuments%20and%20Settings%5CGringo%5CDesktop%5C
StatusBar=1
WindowParams=170;49;818;496;0
ViewStyle=2
ShowFullAddress=1
[Configuration\Interface\Commander]
CoolBarLayout=5,0,0,219,6;1,1,0,522,5;4,0,0,227,4;3,1,0,137,3;6,1,0,145,2;2,1,1,104,1;0,1,1,920,0
CurrentPanel=1
LocalPanelWidth=0,5
StatusBar=1
CommandLine=0
ToolBar=1
WindowParams=66;94;1000;708;0
ExplorerStyleSelection=0
PreserveLocalDirectory=0
CompareByTime=1
CompareBySize=0
SynchronizeBrowsing=1
[Configuration\Interface\Commander\LocalPanel]
CoolBarLayout=2,1,0,137,2;1,1,0,86,1;0,1,1,223,0
DirViewParams=0;1;0|150,1;70,1;101,1;79,1;62,1;55,0|0;1;2;3;4;5
StatusBar=1
[Configuration\Interface\Commander\RemotePanel]
CoolBarLayout=2,1,0,137,2;1,1,0,86,1;0,1,1,224,0
DirViewParams=0;1;0|150,1;70,1;101,1;79,1;62,1;55,0;20,0|0;1;2;3;4;5;6
StatusBar=1
[Configuration\CustomCommands]
&Execute="!"
&Touch=touch%20"!"
Ta&r/GZip=tar%20-cz%20%20-f%20"!%3F&Archive%20Name:%3Farchive.tgz!"%20"!"
&UnTar/GZip=tar%20-xz%20--directory="!%3F&Extract%20to%20directory:%3F.!"%20-f%20"!"
[Configuration\CustomCommandsParams]
&Execute=0
&Touch=3
Ta&r/GZip=1
&UnTar/GZip=0
Screen resolution: dual display (side-by-side) with 1024x768 each.
Re: Catched!
Thanks it helped.
Also, I have removed irrelevant (and possibly sensible) information from your post.
